PC 7424 vs 7336
Old Jun 12, 2006 | 05:23 PM
Clemmdog's Avatar
PC 7424 vs 7336
Is there any reason not to get the 7336 over the 7424? They both seem to have the same specs. But the 7336 is cheaper and is available at Lowes. I just want to know if anybody uses the 7336 for polishing. I know lots of people use the 7424, and I myself was going to buy one, but then I saw the 7336. Comments?
Old Jun 12, 2006 | 06:57 PM
Picus's Avatar
Staff ALUMNI
They're the same, except the 7336 comes with a larger counterweight designed to accomodate larger backing plates (6"), otherwise they are identical in every respect. Mine is a 7336 from Lowes, but if you switched it with a 7427 you would never know the difference.
Old Jun 12, 2006 | 07:06 PM
Clemmdog's Avatar
thanks
Old Jun 12, 2006 | 09:29 PM
nadir's Avatar
get the 7424 from coastaltool.com ... cheapest i've seen and comes with the velcro backing and counterweight ... all that u need for detailing.
Old Jun 12, 2006 | 10:50 PM
BadBoy06's Avatar
check out www.griotsgarage.com they offer a lifetime replacement
for an extra $20- no matter what may go wrong
Old Jun 13, 2006 | 12:20 AM
ksig113's Avatar
This is where I got my PC with lifetime warranty
http://autodetailingsolutions.com/Po...20Specials.htm
Old Jun 20, 2006 | 09:10 AM
mtsl500's Avatar
The 7336 is definitely better if you plan on using Edge pads because you don't have to upgrade the counterweight
7424 - comes with 5" counter weight (good for pads 5" and smaller), you would have to upgrade to 6" to make sure you don't get much wobble with larger pads
7336 - standard 6" counter weight ... can use for almost any size pad.
Old Jun 20, 2006 | 09:12 AM
Clemmdog's Avatar
Thanks all... I got the 7336. Now to get some pads and be on my way
Detailed Image
Jun 23, 2009 07:54 AM
HI Kai G37
Jan 16, 2009 01:15 PM
Detailed Image
Aug 30, 2008 08:11 PM
Detailed Image
Nov 19, 2007 11:21 AM
