Not doing the Zaino madness
Old Nov 12, 2003 | 07:56 AM
cliverman's Avatar
Does anyone has a suggestion for a wax that's a non carnuba based product. It's my understanding that carnuba based waxes actually inhibit a gloss on a lighter colored car. I have a Desert Platinum coupe that I've been using Klasse on but I think it could look "wetter" Wetter is better. : )
Any suggestions? Non Zaino as the title of the tread suggests. Thx - C
BTW: This pic is pre-gialla grill - the car looks better now.
Old Nov 12, 2003 | 10:06 AM
tkman00's Avatar
Re: Not doing the Zaino madness
zaino is better on light colored cars. however if you insist on not going that route, then the klasse is fine. make sure you are using both AIO and SG. for the wet look, you really need to top w/ a carnuba wax. s100/p21s comes to mind, however from what i've heard, pinnacle souveran paste is supposed to be the shizzle for that poured on paint look.
Old Nov 12, 2003 | 10:18 AM
cliverman's Avatar
Thanks tkman00. Good source for P21/s100 or the pinnacle souveran paste?
Old Nov 12, 2003 | 10:42 AM
tkman00's Avatar
you can try autogeek or oddly enough pinnaclewax. detailcity.com forums have some coupons to save you a few bucks. post picks after your done[img]/w3timages/icons/cool.gif[/img][img]/w3timages/icons/cool.gif[/img]
Old Nov 12, 2003 | 05:41 PM
ncozby's Avatar
Why not go Zaino? Althought from all the threads it can sound complicated, it really isn't. It's also much easier to apply and remove than waxes like Meguiars, not to mention the results are amazing.
<font color=blue>2003 G35 BS Sedan AT - St. Louis, MO
Premium, Winter, Xenon w/Silverstar Fogs
35% Tint All Around - Clear Corners
MB Quart / Eclipse Stereo System
PIAA Extreme Whites - K&N Drop-In</font color=blue>
Old Nov 12, 2003 | 06:55 PM
tkman00's Avatar
personally, i'm going to skip the zaino next season and give klasse and pinnacle a shot. i've used zaino for 3 years now, and while the results are impressive, i'm yearning for just a tad more. there are a few other reasons i'm making the switch, but i won't bore you w/ the details.
Old Nov 12, 2003 | 08:24 PM
RamboRami's Avatar
G35driver.com Moderator
try Crystal Guard a.k.a. CG-quick (link is to the left on the sidebar)
It works wonders in under 30 minutes of work-time
G35c-6MT-DG/Willow/HyperGround/BorlaExhaust/350Z-intake
Old Nov 12, 2003 | 09:16 PM
Meatshackle's Avatar
Deep Sea Moderator
Yeah if you don't want to take the time to do Zaino, go the CG route. Everyone seems to be just as happy with CG as they do with Zaino.
Russ
Black w/willow, 6MT Coupe, nav, aero, V1, PS2, & TVs all up in the headrests.
Jax, FL
Old Nov 13, 2003 | 05:16 PM
shodog's Avatar
while I admit zaino is a bit more labor intensive than throwing a coat of wax on the car, you will be amazed. People wouldn't preach so highly about how great it is if the product sucked.
In the past I have had good luck with Meguiars gold class wax. goes on easily and comes off just as easy.
Since I have used Zaino I don't think I would go back.
Jim
'03 Sedan
Brilliant Silver/Graphite
6MT/ Premium package
Sport tuned suspension
Aerodynamic Body Kit
Navigation and Satellite Radio
Old Nov 14, 2003 | 08:34 AM
cliverman's Avatar
I wasn't saying Zaino sucked. I just don't want to spend time applying six different layers of product. I like the way Klasse is easy to apply and does a great job but I want a "wet" look and it really doesn't do that well. Thanks for all the responses.
Old Nov 14, 2003 | 11:02 AM
tkman00's Avatar
if you've already got the zaino on there, and just want that "wet" look, throw some carnuba wax on top of it. i currently have aio topped w/ z5/z2 topped w/ s100 wax. it definitely gave my car that extra little "oomph" i was looking for. when the winter blows over, i'll probably switch to klasse just to see what it looks like.
but for that wet look you definitely need the carnuba
<P ID="edit"><FONT class="small"><EM>Edited by tkman00 on 11/14/03 08:03 AM.</EM></FONT></P>
Old Nov 14, 2003 | 12:31 PM
shodog's Avatar
cliverman, I know you didn't say it sucked. I was reading between the lines. I sense that your turned off by all the hype over zaino.
"I just don't want to spend time applying six different layers of product" I don't know if you were being sarcastic or if you have a misconception of the product. You don't need to apply six different products. It's only 2. for the first coat, either z-1 or the ZFX and for the second coat z2. You can put multiple coats of Z2 on after that if you want. I have 3 coats of z2 on my G and I am satisifed with the outcome.
Now for the wet look, thats a personal choice. You can get it from carnuba wax but that only lasts about a month at best. To maintain that look you will have to re-apply. Carnuba isn't the easiest stuff to get off. That sounds to me like way more work than Zaino.
Jim
'03 Sedan
Old Nov 14, 2003 | 02:03 PM
tkman00's Avatar
shodog
actually the carnubas i mentioned are very easy when it comes to application and removal (easier than zaino, imo). if you apply the same zaino philosophies(lesser product), you can achieve some pretty amazing results. w/ just the zaino, dust attraction borders on extreme. w/ carnuba on top, it's much less the case. granted the surface is not as slick, but the look is amazing. but like you said, in the end it's a personal choice.
Old Nov 14, 2003 | 03:45 PM
tbusguru's Avatar
Some old timer that has owned nothing but Mercedes all his life swears by this product called "Ibiz". any of you know anything about the product?? He said they have a website, I have not checked it out, but it sound like another alternative to an already complicated issue.
Old Nov 15, 2003 | 09:20 AM
cliverman's Avatar
shodog,
You were right when you said I was turned off by all the hype.
And yes I was being sarcastic, but you had to put 4 coats of something to be satisfied even if you didn't have to. How 'bout a pic? I think this will have to be one of those try it, like it or hate it things. I may have to try it just to satisfy me curiosity.
