Quick Zaino Questions
Old Mar 15, 2007 | 02:35 AM
Gam3's Avatar
Red face Quick Zaino Questions
1) when applying z6 do you spray the car..or spray it onto
the applicator and then rub into the paint?
2) when the z2 + zfx dries and you remove it from the paint
do you wash the car then apply z6...or just apply z6 right
away?
3) after applying z6..do you wash the car then dry it then
apply z5 + zfx ...or z2+zfx (vice versa)?
thanks
Old Mar 15, 2007 | 10:42 PM
LT1 SS's Avatar
1) spray it on the car. don't spray too much on.
2) apply z6 after you wipe it off no need to rewash
3) again you don't need to wash
Old Mar 16, 2007 | 10:59 AM
afr0puff's Avatar
Supa Dupa Moderator
Never spray Z6 onto the car if the paint is hot... that $hit is a mug to get off if it dries.
Spray it on an applicator in that scenario.
Old Mar 16, 2007 | 11:26 AM
izmir41500's Avatar
G35driver Addict
Z6 is the quick detailer right? if so, follow the above suggestions. you thoroughly wash the car first before applying anything. you can dry, use z6 to prep the surface if you want but not necessary, apply z2, z6, z5, z6, etc...Or you can do z6 at the end. no need to rewash between coats. follow the tips and tricks on their website.
Old Mar 17, 2007 | 02:31 AM
Gam3's Avatar
thnx for the info guys
408G35Sedan
Feb 23, 2022 06:46 PM
skippyG
Jan 25, 2016 01:18 PM
Th611
Oct 27, 2015 03:48 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
Soumilg
Jul 18, 2015 12:33 PM
