cleaing upholstery
Old Mar 25, 2007 | 05:20 PM
ajlee7's Avatar
cleaing upholstery
Bought in car to my dealer for service and there's a spot on the my roof upholstery. Looks like grease or oil. I don't want to smudge it but can you tell me what I can use to clean it off?
Old Mar 25, 2007 | 05:38 PM
OneFast4DoorG35's Avatar
buy some folex from walmart/target/lowes/HomeDepot, It will basically get anything out of fabric or carpet.
Old Mar 25, 2007 | 11:18 PM
kenchan's Avatar
griots interior cleaner
Old Mar 29, 2007 | 02:54 PM
idwin's Avatar
spray some wd4o on a terry cloth and blot it, then use the folex you should be good to go.
Old Mar 30, 2007 | 03:31 PM
Detailed Image's Avatar
Many different products can work to remove the mark. I've had especially good success with removing grease using the 303 Cleaner and Spot Remover. It cuts through grease really well and most other contaminates. I use it on carpets, head liner, dashboard, doors and much more. Spray the area thoroughly and let it sit for 1 - 2 minutes. Then take a clean cloth and firmly press it upward several different times using a different part of the cloth each time, as not to spread the grease. After you have removed the majority of the grease using this method, now respray the area with the cleaner and lightly brush it with a clean scrub brush. After you can wipe the area again with the cloth just to make sure you have totally removed all the grease. This is my preferred method to remove grease or other stains that have the potential to spread and leave an even worse mark. Let me know if you have any questions about this method or the products I recommended. Good luck with it and let us know how it comes out.
George @ Detailed Image
Old Apr 1, 2007 | 02:26 PM
ajlee7's Avatar
Thanks guys. I used RESOLVE and the stain came right off.
nervseele
Jul 17, 2015 11:21 PM
orscrubs
Oct 21, 2013 09:05 PM
Scrooge
May 31, 2008 10:35 AM
Smartidiot
Canada
Jan 3, 2008 03:07 PM
