Who could have done this
Originally Posted by kernel843
that's true, but if you don't know what you're doing you might spend all this money and not get the desired results and you'll just end up getting frustrated (i'm speaking from experience).
So far I haven't found a good detailer tho so the stuff I couldn't get out is still there and driving me nuts.
That's the beauty of having forums like these. If you fail the first time, there are people here to help you. All you have to do is type out the question. Do keep in mind though that not all imperfections can be removed. I highly suggest that if you have imperfections in your paint and you want to know how to get rid of them that you start up a thread asking for help.
To answer your question, go to any auto store (maybe even Wal-Mart, I'm not sure) and pick up some Meguiars Scratch-X. Read the instructions. Use A LOT of elbow grease (pressure) and rub over the area until the Scratch-X is basically gone. You may have to do two or three applications. When I say use pressure, I mean make the car rock. Just don't push so hard you dent the car. If you work it in until it is basically gone, you won't instill any additional scratches. It works on a dimishing abrasives principle. The abrasives are large at first and then slowly diminish to nothing as you work it in. The final result is scratchless. Make sure you re-wax or seal the area because you will remove anything you had there.
FWIW- ScratchX is made for hand application, diminishing abrasives require friction heat to 'breakdown' and for this reason Megs use normal abrasives in this product
