crspotless
Old Oct 9, 2007 | 08:58 PM
Corvettekid's Avatar
crspotless
Did a quick search, but came up with very little. Anyone know anything about this product, or if it actually works like they say? I would much rather prefer this method over drying any day!
http://crspotless.com/ is the website...
Old Oct 9, 2007 | 11:14 PM
Before bed bump...
Old Oct 10, 2007 | 12:03 AM
redlude97's Avatar
it should work fine, but rather expensive just so you don't have to dry your car. You also have to replace the resin over time
Old Oct 10, 2007 | 01:51 AM
Scrooge's Avatar
It would be good if you want to do a fast wash and wax for a customer. Some people use regular water from the garden hose to do the first rinse and then after washing you rinse it with the CR spotless system.
Old Oct 10, 2007 | 12:44 PM
Glycerine's Avatar
If you're running the garden hose water over it anyway, why not just let the hose sheet the water off, and then mf towel it? Takes me all of 5 minutes to dry off my car :/
Old Oct 10, 2007 | 11:24 PM
Scrooge's Avatar
Well with the CR spotless system, You reduce the chance's of giving the car swirls. Cause you don't need to touch the car after you rinsed it.
Old Oct 12, 2007 | 05:36 AM
TOGWT's Avatar
The CR Spotless DI100WM provides approximately 100 gallons of mineral-free, de-ionized water that will provide spot-free vehicle washing and remove hard water minerals, based on your water input quality. It consists of two 10-inch de-ionization housings that feature replaceable cartridges that simply slide into the watertight tubes. This unit can be mounted next to your hose bib and comes with pre-drilled mounting holes.
Operating costs formula -
Operating costs = 235,000 / TDS * 0.33 cubic feet of resin = Gallons
Cost of refill / Gallons = Final cost of de-ionized water
Using the above formula - hard water area with a total dissolved solids (TDD) meter reading of 550 PPM = (235,000/550) 0.33 cubic feet of resin = 141 gallons. Approximate cost of refill $90, de-ionized water costs me about 65 cents per gallon. Average final rinse 3-5 gallons
http://www.crspotless.com/index
Old Oct 17, 2007 | 03:15 AM
gDriven's Avatar
I have it and it works great! I don't have to go wipe the car dry, which helps with reducing swirls AND it saves me a hellot of time in my details. Wash, clay, rinse and allow to dry in sun.
Old Oct 17, 2007 | 03:17 AM
JOKER's Avatar
CLUB MODERATOR
I saw a thread about this before.
I also think it's too expensive for the car.
MR. Clean car wash kit works just fine.
Old Oct 24, 2007 | 11:31 PM
Haha, soooo...are you FOR, or AGAINST? hahaha. And yea, it does seem expensive, but i think it would make up for it by not having to deal with those annoying water spots.
Old Oct 24, 2007 | 11:54 PM
redlude97's Avatar
wouldn't it be easier to just dry your car correctly I don't have one of those, and I don't get waterspots....
Old Oct 26, 2007 | 02:44 PM
Jeff92se's Avatar
Red Card Crew
It removes the minerals but if you still have water on your car, any dust will catch on the water and will be left on the car after the water finally dries off?
Old Oct 26, 2007 | 04:47 PM
Scrooge's Avatar
Just wondering. Have you tried this system and also have you seen the water spot where the dust got caught on to the water ????
Old Oct 27, 2007 | 01:42 AM
ABQ_G35's Avatar
That depends on where you're located, here, the water is extremely hard, spots form quickly, especially when it's hot. This is what the self serve car washes use for final rinse, but when I use them, I use only the spot free rinse, the pressure is fine. If you figure how much it costs to use the car wash every week, this may pay for itself! It is rather expensive.
And, as far as swirls go, if you wash the car well, and dry with a good microfiber towel, you won't get swirls, from my experience, you get swirls from polishing and waxing more than drying. Right now at home, I use a water softening hose filter to wash, and rinse, then de-ionized water from a pump sprayer for the final rinse, I buy the water by the gallon, around $0.79 per gallon, been using that for about 10 years now.
Old Oct 29, 2007 | 07:37 PM
Jeff92se's Avatar
Red Card Crew
No. But I've let my car dry during a high pollen count day. And you can see where the pollen settles on the drops. Since the pollen is very visible (yellow), you can see how the pollen would act just like dust. My theory anyway
