Tint Problem?
Old Feb 27, 2004 | 01:56 AM
OOOOA3's Avatar
Alumni****
Tint Problem?
just had my tint done.. 20% all around.. i'm very satisfied with the way it looks and visibility is realli good..
anyhow, got a question for you guys.. for all you who had tint done on your coupe, did your window have trouble with the retracting it does when you open the car door? right now, my windows are stuck in the lowered position and don't go back up to make the seal wit the car when i close the doors.. i'm not sure if this is a common problem or not.. so i wanted to ask for some feedback.. i'm tinkin this problem cud go away by itself so i'm giving it a week jus to see how things turn out..
David
03.5 Ivory Pearl G35C 5AT Premium (7-14 ~ 12-10)
04 Ivory Pearl G35C 5AT Premium 18"
Old Feb 27, 2004 | 04:10 AM
Premier's Avatar
Re: Tint Problem?
If it doesn't retract at all, then most likely the installer removed the door trigger at the time of the tint install. All you need to do is turn the car on and roll the window up and it should automatically reset.
Pearl White 2003 Sedan & 2004 Coupe 6MT
Certified Window Tint & Detailing Specialist
Clearshield ("Clearbra") Authorized Dealer
Madico Authorized Dealer
syu@machiii.net
Old Mar 1, 2004 | 01:52 PM
nuttyprof's Avatar
Re: Tint Problem?
i think you should leave it down until the tint completely dries. if it keeps going up and down, you might screw up your tint. but then again, if it rains, it might screw it up too. id say dont drive it for a week, then take it back and have them fix the trigger.
G35S 6MT
Technosquare ECU
350Z Springs & Struts
6-wire ground kit
mattdg35
Sep 14, 2015 11:28 AM
G35-2004-mt6
Sep 11, 2015 04:16 PM
gatorglaze
Sep 10, 2015 12:03 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
