Low temp application of sealents, FMJ
Old Dec 29, 2007 | 02:17 AM
robosdr88's Avatar
Should I be concerned with the ambient temp when applying sealants like FMJ? Seen posts asking about waxes, but none specific about sealants. Looking like outside temps for next few days here will be in the lower 40's. I will be in the garage so I will be a few degrees warmer than outside. I'm really hoping to get two coats of FMJ followed by a couple coats of wax over the next few days. Thanks
Old Dec 29, 2007 | 09:11 AM
Detailed Image's Avatar
As long as the temps are above 40s you should be fine applying and removing the product. With lower temperatures the cure time does take slightly longer if you plan on layering the coats or topping the FMJ with a wax. Ideally, give it a full 24+ hours to let the sealant cure properly.
Let us know how things turn out.
George
Old Dec 29, 2007 | 12:40 PM
robosdr88's Avatar
Thanks George, I post an update on my results
Old Jan 8, 2008 | 08:46 PM
robosdr88's Avatar
I applied two coats of FMJ with about 30hrs between coats. I'm not the best with a camera but here are some shots of the results.
https://g35driver.com/forums/showpos...&postcount=377
Old Jan 9, 2008 | 08:10 AM
Looking great! Your color really pops. What were you thoughts after using Menzerna FMJ? Thanks for sharing!
George
Old Jan 9, 2008 | 11:24 AM
robosdr88's Avatar
Once I got going it was pretty easy to work with. The finished result was nice enough I decided to wait for warmer weather to apply some wax. Overall I'm quite happy with the results. Thanks again George!
BradMD_96
Oct 6, 2015 09:31 AM
hrdwirk1
Oct 2, 2015 06:34 PM
aaron3719
Sep 29, 2015 10:12 AM
wow600rr
Sep 28, 2015 11:50 AM
Detailed Image
Sep 28, 2015 07:04 AM
