Paint Chip Repair??
Old Dec 31, 2007 | 02:00 AM
allstockg35's Avatar
Paint Chip Repair??
Hey guys, i have already researched this matter but i still have couple questions about fixing paint chips. The chip that i have is is about 1 X 3/4 inch. Should i fill it in with touch up paint then wetsand it or should i apply a coat of clear over the touch up paint before sanding since its such a large area? Also what grit of sandpaper do you guys recomend when wetsanding, 2000 or 2500?
Old Dec 31, 2007 | 01:59 PM
Scrooge's Avatar
2500 wet sand with a sanding block. Also do you a have buffer to remove the wet sanding ????
Old Dec 31, 2007 | 10:01 PM
Yes, i have the pc buffer. But do you still think i should clear coat it since its such a large area. Also do you think using Meguiars Swirl Remover 2.0 will be enough take out scratches after wetsanding with 2500 grit or should i use something more abrasive like their fine cut clearner?
Old Jan 1, 2008 | 12:29 AM
Scrooge's Avatar
Try number #83. Cause #9 won't take it out.Some people put clear coat and some don't. Just matter what you want to do.
alessandro
Oct 8, 2015 09:29 AM
cmesidewayz
Sep 29, 2015 09:28 PM
itgogitrev
Sep 25, 2015 10:28 AM
TNRocker
Sep 21, 2015 08:36 AM
toadfire
Sep 21, 2015 07:15 AM
