Torn Leather Seats... Help!!!
Old Mar 7, 2008 | 10:28 PM
Vic's Avatar
Vic
I accidently stabbed the bottom part of the seat with a pencil. Don't ask me why.. I did not even know how did that happen...
The leather is about 0.5 inch torn. It's quite small, but I need to get it fixed as soon as possible before the tear is getting worse.
So, Please HELP me.. what should I do? How and Where can I fix it?
Should I bring it to the dealer? I'm just afraid they will charge me with an unbelievable price.
Any suggestions??
Old Mar 7, 2008 | 10:48 PM
Andy2434's Avatar
Any suggestions??
I'd check with a good auto upholstery shop first. You should be able to find one in the phone book in your area. Good luck with your fix.
Old Mar 7, 2008 | 11:39 PM
Vic's Avatar
Vic
Andy, thanks for the suggestion. That is a good Idea.. let me check on the yellow pages.
I live in Ann Arbor, Michigan. So, does anyone in Michigan have any recommendation on good auto upholstery shops?
Thanks....
Old Mar 8, 2008 | 03:22 AM
Beebo's Avatar
^^^ yeah just look for a good shop... the dealer will want to replace the bottom of the seat and that cost $1600
Old Mar 8, 2008 | 03:28 AM
Vic's Avatar
Vic
anyone know how they will fix the tear? will the damage still be visible after the fix?
Old Mar 8, 2008 | 08:54 AM
TOGWT's Avatar
Repairing Cuts and Tears in Leather:
A cut through the leather must be repaired with a patch on the underside.
Methodology
•Clean and prepare the leather surfaces as in 12a above
•Slice through with a one-sided razor blade to gain access to the underside. The leather patch must be larger than the cut, work the patch into the hole so it can be glued to the underside of the seat leather, suede sides together.
•Use suitable leather adhesive that can be sanded (Rightlook leather adhesive, Rightlook.com) do not use contact cement because it adheres instantly when the two surfaces touch, which would prevent an inside patch from being worked into position.
•Apply the glue through the hole so that both the seat leather and patch are coated
•Work the patch into place, then press the two pieces together and hold them there until the glue sets up. After the glue has cured fill the repaired cut with flexible filler
Old Mar 19, 2008 | 12:12 PM
FuSiOn's Avatar
I had my driver seat ( the bottom) replaced with new leather top and new foam for free at the dealer...Took it in for a claim telling them the materials was defective and had it replaced... basically the foam was wearing out causing the leather to tear on the left hand side of the seat....
seagrasser
May 3, 2022 09:43 AM
nissandrifter32
Dec 22, 2015 04:28 PM
NailBomb
Oct 28, 2015 07:53 AM
MrIP35
Oct 25, 2015 11:13 PM
TNRocker
Sep 21, 2015 08:36 AM
