Inbetween all the buttons
My heat-seater and seat control buttons are all dirty, sticky, and yucky. How do I go about cleaning these?
EDIT: Also how do I clean the aluminum console?
Thanks in advanced folks.
Don't waste your time with a q-tip. I use a brush similar to this.
http://www.detailersdomain.com/index...ROD&ProdID=386
You can find the one I have in Michaels for $3-6. It's close to the same but Swissvax brushes are pretty much the best. I would recommend just picking the Swissvax brush up.
So just spray the area with this:
http://www.detailersdomain.com/index...ROD&ProdID=117
Then brush it with your choice of brush and wipe off with a microfiber towel. If theres some residue left over from the cleaner just mist some water and wipe off again. If you want you can protect it with this:
http://www.detailersdomain.com/index...ROD&ProdID=353
That stuff I linked you are expensive products, but they work well. In general any All Purpose Cleaner will work the same and any Vinyl/Rubber Protectant will as well. You can get a gallon of Meguiars All Purpose Cleaner for $15 or so and a gallon of Finish Kare 108 for about the same I believe. Just make sure to pick up some spray bottles
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
