Small paint problem
Old May 20, 2009 | 11:28 AM
shoeless's Avatar
Small paint problem
Guys,
I was cleaning the car this last weekend and I had som tar-like substance that would not respond to any bug/tar spray+simple elbow grease. Mistakenly, there were two or three quarter-sized ares where I gently (I thought it was gentle) rubbed with a scotch-brite pad to clean it off. I didn't get any paint on the pad, so I don't think I broke trough the clear coat, but after waxing, it was obvious from certain angles that the paint doesn't look quite right in these three spots. The finish is smooth, as as I said, the differences are only noticable from certain angles.
Is there anything I can do to make these spots less noticable?
Thanks
Old May 20, 2009 | 11:31 AM
Detailed Image's Avatar
Originally Posted by shoeless
Guys,
Thanks
You should be able to minimize the spots if not eliminate them by properly polishing your paint. Depending on how hard you pushed and how deep the imperfections are will determine the level of polish needed. A good starting point if you plan on doing it by hand would be Meguiar's ScratchX, which can be found locally. Ideally, to really make a stab at removing them completely, you'll want to use a quality buffer. If you already have a buffer, I'd suggest using something like Menzerna Power Finish on a white or green pad.
Hope this helps,
George
Old May 20, 2009 | 02:30 PM
shoeless's Avatar
Thanks. I'll give it a try. Can I use a buffer with scratchX, or is that just futile?
Old May 21, 2009 | 08:56 AM
ScratchX can be applied with a buffer, definitely. I think there are better polish options though if you do have access to a buffer.
Keep us posted on how things turn out.
George
skippyG
Jan 25, 2016 01:18 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
derres
Aug 28, 2015 03:27 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
lilscsteve
Jul 21, 2015 04:01 PM
