cracks on side of driver's seat
Old Jun 5, 2009 | 12:53 AM
miamichillin99's Avatar
Any tips on smoothing out the cracks on the sides of the leather seats?
Old Jun 5, 2009 | 06:18 AM
TOGWT's Avatar
Scratched or cracked leather - upholstery fibre structure will stretch in all directions with no particular grain or stress pattern. The urethane surface coating will not withstand multi directional stress, however, and when it’s flexed or stretched continuously in the same place the surface coating develops minute cracks. Repeated flexing and stretching eventually causes the pigmented urethane surface coating to wear away in certain areas.
By using this kit from Leather Magic; wipe the leather down with the solution, using the 220 grit sand paper; this will remove most of the minor creases. Apply 3-4 thin coats of dye (allow to dry between coats) you have the option to spray the final coat with a sprayer (all included in kit) – Leather Magic Repair
An extract from one of a series of in-depth detailing articles © TOGWT ™ Ltd Copyright 2002-2008, all rights reserved
mbe093
Lights
Oct 2, 2016 11:09 PM
si_driver
Interior
Jul 25, 2015 09:22 AM
si_driver
Jul 16, 2015 09:40 PM
