Help Me Out, Headlight Wet sanding...
Old Jun 9, 2009 | 11:00 PM
urbanlife's Avatar
I'm going to go ahead and wet sand my headlight cause I haven't been able to get that clean clean look I want after using PlastX. Yes it did clean them a lot but not near what I was looking for. So my question is what are the steps I should take to wet sand and polish my headlight. I'll be using a PC to buff them up so can anyone here help me out and tell me how do I go about doing so. Also after I wet sand and polish what can be use to seal the headlights up so it can maintain it from hazing up again. Thanks in advance.
Old Jun 9, 2009 | 11:52 PM
EASTCOAST_G35's Avatar
I used the 3M headlight restoration kit, it actually works really well. and you can wash the polishing pad and re-use it. i use it with plastx and my headlights are crystal clear.
Old Jun 10, 2009 | 10:40 AM
urbanlife's Avatar
thanks for your reply, I'm gonna try it. But I'm also looking for a plastic sealer to apply after the restoration to help slow down the the hazing from coming back. Anyone know which is a good one to use?
Old Jun 11, 2009 | 06:32 AM
TOGWT's Avatar
Apply a sealant for general prtection and 303 Space Protectant to provide UV protection (Yellowing)
Headlight Protection
Protect your expensive headlamps, before it's too late. LampGard™, an incredibly tough 40 mil thick, double-polished urethane material that is optically clear and applies (peel & stick) directly to the surface. This product has built-in ultraviolet inhibitors that help prevent the material from drying, hardening or discolouring. We custom die-cut to fit your specific vehicle for a precise, perfect fit, it comes with easy-to-follow instructions and applies to headlamps, fog lamps, turn indicators and parking lights (when applicable) to protect them from scratching, cracking and pitting. LampGard™
An extract from one of a series of in-depth detailing articles © TOGWT ™ Ltd Copyright 2002-2008, all rights reserved
Old Jun 11, 2009 | 06:52 AM
urbanlife's Avatar
Thanks, I'll look into that as well. Sounds great.
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
