20% Off Chemical Guys products: 6/26 - 6/29
Old Jun 26, 2009 | 12:05 PM
Detailed Image's Avatar
Chemical Guys is known for providing great products at an excellent price point. Bang for the buck they are some of the most economical products out there, especially with their gallon sizes. Take advantage of 10% off gallon sizes and 20% off every other Chemical Guys product we offer, valid through June 29th.
Read what professional detailer, Todd Cooperider, owner of Esoteric Auto Detail, has to say about Chemical Guys Citrus Wash & Clear and Chemical Guys Fade 2 Black.
Best selling Chemical Guys Products:
JetSeal 109 sealant - an extremely easy to apply and remove sealant that gives a look similar to a carnauba wax with lasting durability.
Maxi Suds II - an outstanding maintenance shampoo that will maintain your coats of protection with it's gentle cleaners. Foams up nicely making it great for foam guns as well!
EZ Creme Glaze - a great acrylic glaze that works well under a sealant or a wax. Easy to use and helps enhance the depth and gloss of any color paint.
Citrus Wash & Gloss - A versatile shampoo that can be diluted down as a maintenance shampoo or used in high concentration to strip off previous coats of protection for a fresh start or to remove polishing oils and dust.
Microfiber Detergent
- keep your microfiber fresher, longer, by using a detergent specifically designed for microfiber. Helps remove product build up and debris, without clogging the pores of your microfiber.
Speed Wipe (Anti-Static) QD - Follow up your maintenance washes with CG Speed Wipe to enhance the gloss and depth of your paint with anti-static properties to help minimize dust accumulation. Easy to apply and remove to a streak free finish.
50/50 Limited Edition Wax - This wax is a sleeper for maximum value in a carnauba wax. Get 16 oz (more than double most of our waxes) of a high quality carnauba wax that makes any color really pop. On a per ounce basis this wax is tough to beat!
2 New Chemical Guy's Editions to Detailed Image
Luber in 128 oz
- Chemical Guys Luber is an outstanding clay lube that provides a very slick surface for you to glide your clay over. Using a quality clay lube such as Luber will help minimize the risk of marring your finish as you clay. Wipes up easily and streak free and can also be used as a quick detailer.
Medium Grade Clay Bar - Use this medium grade clay for stubborn contamination such as paint overspray, sap, tar, and other things that don't easily get removed from a normal maintenance wash. With 200g, this is a great value for clay bars.
Thanks for reading, if you have any questions on anything or need a hand selecting any products, please do not hesitate to ask.
Have a great weekend!
George
Mry
Mar 3, 2023 01:03 AM
bTanz
Oct 15, 2015 02:31 PM
Detailed Image
Aug 10, 2015 02:29 PM
Tylerttn
Jul 16, 2015 10:33 AM
Tylerttn
Jul 13, 2015 04:26 PM
