Cleaning Inner Rim on OEM 19's
Old Jul 26, 2009 | 08:57 PM
Jairen's Avatar
I have a lot of dirt and brake dust built on the inner part of my OEM 19's.
Normal soap and rags will not get it off. It's almost caked on. The inner rim looks brown while the outside is squeaky clean.
Any recommendations on how to get it off?
Old Jul 26, 2009 | 09:11 PM
JAYY-G35's Avatar
Take em off, try to wash em down. if that don't work try a degreaser
Old Jul 26, 2009 | 09:23 PM
WhosRich's Avatar
try something acidic. "Meguiars Hot Rims" or "Eagle One A2Z wheel cleaner". those are pretty strong OTC wheel cleaners. if youre going to order them online, id try "Meguiars Wheel Brightener". Just remember to follow the directions exactly and you should be fine.
Old Jul 26, 2009 | 09:45 PM
j 4 lD's Avatar
I just did the same thing you are about to do. I took off all my wheels and cleaned them with a wheel cleaner/degreaser like this one:
It took off most of the dirt and grime, but some of it still remained. I only used a regular car washing mitt though.
Old Jul 26, 2009 | 10:59 PM
Chris82xx's Avatar
The best thing for you to do is take them off and hit them with Purple Power. The stuff is the best. Let it sit for a couple of minutes, but not too long because it will eat the rim. Use a hard bristled brush and rinse with a power washer.
Old Jul 26, 2009 | 11:14 PM
Jairen's Avatar
I took them off and tried Purple Power. Still brown and dirty looking. Regular off the shelf wheel cleaner doesn't touch it.
I did a small section, 4"x4" with metal polish and got a lot of it off. Looks like it's the only thing that will work. The small section is "hella" clean.
The drawback is the amount of time and elbow grease may not be worth the hassle.
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Gip
Aug 24, 2015 05:31 PM
johnjohn077
Audio/Video/Electronics
Aug 5, 2015 03:09 AM
johnjohn077
Brakes
Aug 4, 2015 01:37 AM
