Porter Cable 7424
Old Aug 6, 2009 | 11:24 PM
ChrisG35Driver's Avatar
Porter Cable 7424
I am about to buy this and someone posted something saying it should only be used for correction and not waxing????? So is this a once a year (or less) tool?????
Old Aug 7, 2009 | 01:19 AM
oyoquem's Avatar
Wax doesn't require pressure so using a buffer will just be a waste if that's what you want it for. It helps with correction because it provides the steady pressure and heat needed to breakdown a polish. You will probably use it about twice a year on your own car but you can polish other peoples cars to make some extra cash. At least that's what I would do.
Old Aug 7, 2009 | 08:57 AM
DetailDan's Avatar
Not true at all. You can use the PC to apply waxes and sealants.
Old Aug 9, 2009 | 03:41 AM
NAMEL355's Avatar
Its not needed for waxing but its easier till doing it all by hand and faster. Just use the right pad/bonnet.
Old Aug 9, 2009 | 01:50 PM
FlSHRFun's Avatar
It can be used for applying waxes and sealants. Just use a soft finishing pad and apply no pressure, just the weight of the machine and your hands.
You can use Lake Country's softest Blue Finishing Pad or their Black Finishing Pad.
It is helpful whenever you may need paint correction. Then, you'll need a good abrasive polish/compounds and a good cutting/polishing pad.
I only polish my car about 2-3 times a year, but I detail other cars on the side as a hobby/side-job.
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
JustinMKN1
Sep 18, 2015 03:40 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
