Detailing tip of the week
Old Mar 3, 2010 | 03:48 PM
SWGUY's Avatar
I know i dont know everything there is about detailing or cleaning cars or products but i do know some tips i've learned so i figure why on share them and others can too....
let me know if this a good thread to follow...
and here is mine...
so Maintianing your wheels finish while mazimizing shine is easy you could Start by cleaning wheels first then Applying a quick coat of RIMWAX of your choice bi-weekly and it will help reduce brake dust by 50% while enhancing and maintianing your rim and wheel finishes for years to come, it's work for me.....DOMO
Old Mar 11, 2010 | 04:30 PM
SWGUY's Avatar
Detailing tip of the week: reason why a microfiber towel has two sides is because one side its for applying a product and the other to buff the product off. that's why always be picky about the towels you buy and what you use them for...
Old Mar 11, 2010 | 05:06 PM
Deepdiver's Avatar
umm..don't all towels have two sides?
Old Mar 11, 2010 | 05:19 PM
SWGUY's Avatar
on some one side is softer than the other...
Old Mar 11, 2010 | 05:22 PM
Darkstar752's Avatar
I believe he means the towels that have 2 different nap lengths on either side, one side short and the other side fluffier.
And OP, what products do you use the are applied by a quality microfiber that has two sides? You shouldn't really use microfibers to apply products, they have split strands and you're going to waste A LOT of product since the split strand will absorb the product into it, rather than applying it. It will clog and reduce the effectiveness of the microfiber, since the reason it cleans so well is the fact that it can absorb the stuff you don't want on the paint into the microfiber, instead of just being dragged along the paint. The long nap side should be used for products such as a quick detailer to remove light dirt, dust, etc, while the shorter side is great for buffing off products since the shorter nap will not move around as much.
There's a great microfiber information thread posted as a sticky in this forum, read up on it.
Old Mar 17, 2010 | 03:55 PM
SWGUY's Avatar
found it...great info...
now anyone other tips we should know about?
Old Mar 17, 2010 | 09:07 PM
jibberjabbers's Avatar
i use regular cleaner wax on my wheels. i use cleaner wax for everything really. haha
but for paint, i finish off with mothers pure carnuba wax. inexpensive and gives me the best shine so far.
Old Mar 24, 2010 | 01:55 PM
SWGUY's Avatar
Detailing tip of the week : what to do first when detailing your car (interior, engine, wheels and last exterior)
Old Mar 24, 2010 | 01:58 PM
thescreensavers's Avatar
Mr.202?
Interior>Wheels> Exterior is how I do it.
does not really matter only thing is to do wheels before the body.
Old Apr 1, 2010 | 02:22 PM
SWGUY's Avatar
Detailing tip of the week: when fully detailing the exterior of your car (wash,clay,seal,glaze,wax) you should be using 6-12 towels min. preferable double sided microfiber towels with silk trimming
Old Apr 8, 2010 | 06:34 PM
SWGUY's Avatar
Detailing tip of the week " when applying dressing to your interior vinyl apply gently as if you did with wax in a circular motion but to reduce it from attracting dust after applying the dressing, simply wipe down with a microfiber towel to give it a fresh look"
Old Apr 9, 2010 | 05:50 PM
DHCrocks's Avatar
I like to spray the dressing onto a applicator and then wipe the panels. this way overspay won't get onto the windows which is hard to remove since it's oily and just smears on glass.
Old Apr 9, 2010 | 10:37 PM
ckp's Avatar
ckp
I use the same wax i use on my paint for my rims. is that ok? (I only used it once on my rims)
Old Apr 9, 2010 | 10:49 PM
Deepdiver's Avatar
that's what makes this stuff great. Not glossy, repels dust, and no overspray.
Old Apr 14, 2010 | 04:48 PM
SWGUY's Avatar
detailing tip of the week: "for those that do car shows or just simply want to use no water to clean your rim & tires on the spot, we have a solution...use any citrus base product like carpet cleaner or _______ blended with water on the rim & tire, wipe off with a microfiber towel to a perfect clean surface" app...ly more if needed. this process is good on any type of finishes.
depends which wax but i know most carnauba serve the same purpose.
