New FREE Car Care Product every week at DetailedImage.com
Old Feb 4, 2015 | 11:13 AM
  #211
Detailed Image's Avatar
This week's Weekly Special is DI Brushes Pet Hair Removal Brush.
Use Coupon Code WSPETHA0615 to receive it for Free. A $4.99 value! Min spend $20. Offer ends 2/10/15 at 11:59 PM EST.
  • Easily remove pesky pet hair from your interior carpets and upholstery
  • Rubber bristles use static electricity to attract and collect pet hair
  • Great for removing hair from furniture and carpets in your home too!
  • Handle can be used as a squeegee to remove water from windows
Old Feb 11, 2015 | 09:27 AM
  #212
This week's Weekly Special is DI Microfiber Waffle Weave Drying Towel - 36" x 24".
Use Coupon Code WSWAFFL0715 to receive it for Free. A $13.49 value! Min spend $60. Offer ends 2/17/15 at 11:59 PM EST.
  • One of the best options for drying your vehicle safely and quickly
  • Continues to soak up large amounts of water even after it's damp or wet
  • A fine silk edging ensures this is a safe towel
  • This towel can hold up to 10 times its weight with water
  • Use this towel with the sheeting method for the most efficient drying process
  • 480 GSM
Old Feb 18, 2015 | 08:51 AM
  #213
This week's Weekly Special is DI Accessories Fine Grade Clay - 200 g.
Use Coupon Code WSFINEG0815 to receive it for Free. A $18.99 value! Min spend $35. Offer ends 2/24/15 at 11:59 PM EST.
  • Safely remove road grime, brake dust, tar, sap, paint over spray and more
  • Fine grade clay bars are gentle on your exterior paint
  • We recommend using Dodo Juice Born Slippy or Poorboy's World Spray & Wipe as your clay lube
  • Can be used on brand new cars to older vehicles with light to medium build ups
Old Feb 25, 2015 | 08:02 AM
  #214
This week's Weekly Special is Sonax Wheel Cleaner Full Effect - 500 ml.
Use Coupon Code WSWHEEL0915 to receive it for Free. A $15.99 value! Min spend $70. Offer ends 3/3/15 at 11:59 PM EST.
  • Sonax Wheel Cleaner 2 pack & Bonus Dashboard Cleaner ONLY $30!!!
  • Extra strong wheel cleaner that is very gentle and pH neutral
  • Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
  • The 500ml bottle's spray nozzle provides a fine mist and steady stream which helps conserve product
  • A premium wheel cleaner professional detailers absolutely love
  • Sprays on fluorescent green and changes to a deep red as it reacts with contaminants on your wheel
Old Mar 4, 2015 | 08:17 AM
  #215
This week's Weekly Special is P21S Gel Wheel Cleaner - 500 ml Kit.
Use Coupon Code WSGELWH1015 to receive it for Free. A $19.99 value! Min spend $85. Offer ends 3/10/15 at 11:59 PM EST.
  • One of the safest, most effective, pH balanced wheel cleaners on the market
  • Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
  • Perfect option for after market wheels as it is safe for virtually any wheel surface
  • Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
  • Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
Old Mar 11, 2015 | 08:32 AM
  #216
This week's Weekly Special is P21S Deluxe Wax Applicator 2 Pack.
Use Coupon Code WSDELUX1115 to receive it for Free. A $9.99 value! Min spend $40. Offer ends 3/17/15 at 11:59 PM EST.
  • Apply any polish, glaze, sealant or wax with the P21S Deluxe Applicator
  • Includes 2 premium foam applicators
  • Very soft and safe on any surface
Old Mar 25, 2015 | 08:32 AM
  #217
Use Coupon Code WSGELWH1315 to receive it for Free. A $19.99 value! Min spend $120. Offer ends 3/31/15 at 11:59 PM EST.
Old Apr 1, 2015 | 08:28 AM
  #218
This week's Weekly Special is P21S Finish Restorer - 75ml.
Use Coupon Code WSFINIS1415 to receive it for Free. A $11.99 value! Min spend $90. Offer ends 4/7/15 at 11:59 PM EST.
  • Clean, restore and polish your wheels and metal trim in one easy step
  • A little goes a long way, work a small amount of product into the metal with light pressure
  • We recommend using a foam applicator pad for application
  • Use a two sided metal polishing towel to remove excess product and to buff to desired finish
Old Apr 8, 2015 | 08:54 AM
  #219
Use Coupon Code WSGELWH1515 to receive it for Free. A $19.99 value! Min spend $120. Offer ends 4/14/15 at 11:59 PM EST.
Old Apr 15, 2015 | 08:57 AM
  #220
This week's Weekly Special is DI Microfiber Applicator Pad - Rectangle.
Use Coupon Code WSAPPLI1615 to receive it for Free. A $2.99 value! Min spend $5. Offer ends 4/21/15 at 11:59 PM EST.
  • Ideal for applying a sealant or wax, can also be used for polishes, glazes and more
  • Very soft and safe applicator
  • It should last years if you hand wash the Microfiber Applicator
  • Can be used to apply interior care products like leather cleaners and conditioners, trim restorers and other protectants
  • 300 GSM and reusable!
  • Comes in two great shapes, rectangle and circle!
Old Apr 22, 2015 | 08:23 AM
  #221
This week's Weekly Special is DI Accessories Sheepskin Wash Mitt without thumb.
Use Coupon Code WSSHEEP1715 to receive it for Free. A $8.99 value! Min spend $75. Offer ends 4/28/15 at 11:59 PM EST.
  • All natural fibers makes it one of the safest wash mitts on the market
  • The natural fibers help pull contamination away from the surface without harming even the most delicate finishes
  • When done rinse any contamination away using free flowing water than hang dry with leather loop
  • Can be used with any shampoo or rinseless wash (i.e. Optimum No Rinse Wash & Shine New Formula (ONR))
  • Also available in the with thumb version!
Old Apr 29, 2015 | 08:48 AM
  #222
This week's Weekly Special is Einszett Cockpit Premium - 500 ml.
Use Coupon Code WSCOCKP1815 to receive it for Free. A $11.99 value! Min spend $55. Offer ends 5/5/15 at 11:59 PM EST.
  • One of the best interior cleaners and protectants that leaves your finish factory new
  • Easy to get streak free results every time, great scent, and UV protects
  • Best used on your dash, gauge cluster, navigation screens, audio components, shift *****, arm rests, leatherette, steering wheels and much more
Old May 6, 2015 | 08:33 AM
  #223
This week's Weekly Special is DI Brushes ATLASTA Soft Tip Brush.
Use Coupon Code WSATLAS1915 to receive it for Free. A $14.99 value! Min spend $70. Offer ends 5/12/15 at 11:59 PM EST.
  • Versatile brush can be used on your interior or exterior surfaces!
  • Packed with soft filament bristles that hold their shape
  • 9.75" long with a weight of 4.3 oz
  • Amazing brush for wheels!
Old May 13, 2015 | 08:35 AM
  #224
This week's Weekly Special is P21S Bodywork Conditioning Shampoo - 500 ml.
Use Coupon Code WSBODYW2015 to receive it for Free. A $11.99 value! Min spend $55. Offer ends 5/19/15 at 11:59 PM EST.
  • An excellent, shampoo with high lubricity and gentle cleaners that will not remove your protection
  • Only a cap full of shampoo is needed in a 5 gallon bucket of water
  • The low sudsing formula does not make this a great shampoo for a foam gun
  • Best applied with a sheepskin wash mitt along with a Grit Guard bucket insert
Old May 20, 2015 | 08:33 AM
  #225
This week's Weekly Special is 303 Aerospace Protectant - 16 oz.
Use Coupon Code WSAEROS2115 to receive it for Free. A $12.99 value! Min spend $60. Offer ends 5/26/15 at 11:59 PM EST.
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
