New FREE Car Care Product every week at DetailedImage.com
Old May 4, 2016 | 08:37 AM
  #271
Detailed Image's Avatar
This week's Weekly Special is DI Brushes Foam Pad Cleaning Brush.
Use Coupon Code WSFOAMP1816 to receive it for Free. A $1.99 value! Min spend $5. Offer ends 5/10/16 at 11:59 PM EST.
  • Helps remove excess product trapped in your buffing pad
  • Safe on all foam pads and very easy to use
  • Helps prolong the life of pads and keep them in ideal working condition
  • 8" contorted handle and .75" nylon bristles
Old May 11, 2016 | 08:34 AM
  #272
This week's Weekly Special is DI Brushes Boar's Hair Detailing Brush - 1".
Use Coupon Code WSBOARS1916 to receive it for Free. A $15.99 value! Min spend $85. Offer ends 5/17/16 at 11:59 PM EST.
  • Use it to clean your wheels, exterior trim and so much of the interior
  • Ultra soft boar's hair fibers make it safe to use everywhere
  • Very durable design and fibers so you can use this brush for years
  • Helps clean tough to reach areas safely and easily
Old May 25, 2016 | 08:05 AM
  #273
This week's Weekly Special is 303 Automotive Speed Detailer - 16 oz.
Use Coupon Code WSAUTOM2116 to receive it for Free. A $8.99 value! Min spend $40. Offer ends 5/31/16 at 11:59 PM EST.
  • Clean, shine and protect paint with ease
  • Adds protection to resist contamination and UV rays
  • Spray on and wipe off easy application
  • Can be used on paint, glass, fiberglass, plastic, metal, etc.
Old Jun 1, 2016 | 08:34 AM
  #274
This week's Weekly Special is DI Accessories Fine Grade Clay - 100 g.
Use Coupon Code WSFINEG2216 to receive it for Free. A $10.99 value! Min spend $25. Offer ends 6/7/16 at 11:59 PM EST.
  • Safely remove road grime, brake dust, tar, sap, paint over spray and more
  • Fine grade clay bars are gentle on your exterior paint
  • We recommend using Dodo Juice Born Slippy or Poorboy's World Spray & Wipe as your clay lube
  • Can be used on brand new cars to older vehicles with light to medium build ups
Old Jun 8, 2016 | 08:29 AM
  #275
This week's Weekly Special is DI Accessories Yellow Foam Applicator Pad.
Use Coupon Code WSYELLO2316 to receive it for Free. A $1.49 value! Min spend $5. Offer ends 6/14/16 at 11:59 PM EST.
  • Most commonly used for applying polishes, glazes, sealants, and waxes!
  • Helps you apply a thin and even coating over any surface for maximum results
  • Washable and reusable so they provide a great value for years to come
Old Jun 15, 2016 | 08:54 AM
  #276
This week's Weekly Special is P21S Paintwork Cleanser - 350 ml.
Use Coupon Code WSPAINT2416 to receive it for Free. A $15.99 value! Min spend $85. Offer ends 6/21/16 at 11:59 PM EST.
  • Properly preps your paints surface prior to applying a wax while adding depth and gloss
  • Best applied just after polishing your paint to remove imperfections
  • Can be applied either by hand with a foam applicator pad or via buffer and a black or blue pad
  • Excess product should be removed with a quality microfiber towel
Old Jun 22, 2016 | 08:22 AM
  #277
This week's Weekly Special is P21S Total Auto Wash - 1000 ml Kit.
Use Coupon Code WSTOTAL2516 to receive it for Free. A $19.99 value! Min spend $85. Offer ends 6/28/16 at 11:59 PM EST.
  • Degrease nearly any surface safely and effectively
  • Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
  • Can be used at full strength or diluted down to clean more delicate surfaces
  • Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
  • A must have any detailing enthusiasts or pro detailers arsenal of products
Old Jul 6, 2016 | 08:33 AM
  #278
This week's Weekly Special is Meguiar's Soft Buff DA Foam Polishing Disc - 5".
Use Coupon Code WSSOFTB2716 to receive it for Free. A $8.24 value! Min spend $45. Offer ends 7/12/16 at 11:59 PM EST.
  • Polishing disc that makes quick work of medium to light imperfections!
  • Low operating temperature and less haze left behind
  • Thin 17.5mm disc design
  • Works on the MT300 or any other DA Polisher
  • Perfect fit on the Soft Buff DA Backing Plate
Old Jul 13, 2016 | 08:23 AM
  #279
This week's Weekly Special is Poorboy's World Natty's Black Paste Wax - 8 oz.
Use Coupon Code WSNATTY2816 to receive it for Free. A $29.99 value! Min spend $105. Offer ends 7/19/16 at 11:59 PM EST.
  • Greatly enhances the way dark colored paint looks!
  • Easy to apply wipe on, let haze, wipe off formula
  • Can be applied to any color paint to add gloss and depth
  • 1 jar gives you 20+ applications
Old Jul 22, 2016 | 10:33 AM
  #280
This week's Weekly Special is Lake Country HD Orbital Blue Cutting Pad - 7".
Use Coupon Code WSHDORB2916 to receive it for Free. A $15.99 value! Min spend $65. Offer ends 7/26/16 at 11:59 PM EST.
  • The most aggressive LC HD Pad, designed to remove heavy scratches, swirls, and defects.
  • Runs 10% cooler than traditional Lake Country pads
  • Perfectly balanced, cushioned, and features thinner foam
  • Removes imperfections easily while reducing hazing and marring from heavier polishing compounds
Old Jul 27, 2016 | 08:13 AM
  #281
This week's Weekly Special is Meguiar's DA Microfiber Cutting Disc Buffing Pad - 2 pack - 5".
Use Coupon Code WSDAMIC3016 to receive it for Free. A $21.99 value! Min spend $110. Offer ends 8/2/16 at 11:59 PM EST.
  • Exceptional cutting power that removes swirls while finishing down crystal clear
  • Combine this pad with the Meguiar's DA Microfiber Correction Compound for best results
  • Includes 2 Pads
  • A brand new technology that is changing the detailing world
  • Use a Porter Cable 7424 XP and the Meguiar's Soft Buff DA Backing Plate
Old Aug 3, 2016 | 08:15 AM
  #282
This week's Weekly Special is DI Brushes Pet Hair Removal Brush.
Use Coupon Code WSPETHA3116 to receive it for Free. A $3.74 value! Min spend $25. Offer ends 8/9/16 at 11:59 PM EST.
  • Easily remove pesky pet hair from your interior carpets and upholstery
  • Rubber bristles use static electricity to attract and collect pet hair
  • Great for removing hair from furniture and carpets in your home too!
  • Handle can be used as a squeegee to remove water from windows
Old Aug 17, 2016 | 08:48 AM
  #283
Use Coupon Code WSPAINT3316 to receive it for Free. A $15.99 value! Min spend $95. Offer ends 8/23/16 at 11:59 PM EST.
Old Aug 24, 2016 | 08:23 AM
  #284
Question
This week's Weekly Special is Rupes White Finishing Foam Pad - 1.25".
Use Coupon Code WSWHITE3416 to receive it for Free. A $6.99 value! Min spend $25. Offer ends 8/30/16 at 11:59 PM EST.
  • Bring back that deep glossy finish safely and easy!
  • Removes ultra fine imperfections and finishes down extremely well
  • Pairs great with the Rupes Diamond Ultra Fine Gel Polish
Old Aug 31, 2016 | 08:26 AM
  #285
This week's Weekly Special is 22ple Glass Coat Applicator (Double Sided).
Use Coupon Code WSGLASS3516 to receive it for Free. A $5.99 value! Min spend $25. Offer ends 9/6/16 at 11:59 PM EST.
  • High quality applicator pad for applying your favorite coating
  • Two sided for double the use!
  • Will not soak up excess product, applications are easier and you waste less product
  • One of the most efficient ways for applying your 22ple coatings
