New FREE Car Care Product every week at DetailedImage.com
Oct 13, 2011 | 11:45 PM
  #46
Quote: This week's Weekly Special is SONAX Wheel Cleaner Full Effect - 500 ml.
Use Coupon Code WSWHEEL4111 to receive it for Free. A $15.99 value! Min spend $90. Offer ends 10/18/11 at 11:59 PM EST.
  • Sprays on fluorescent green and changes to a deep red as it reacts with contaminants on your wheel
  • Extra strong wheel cleaner that is very gentle and pH neutral
  • Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
  • High quality spray nozzle provides a fine mist and steady stream which helps conserve product
  • A premium wheel cleaner professional detailers absolutely love
The absolute best wheel cleaner out there. Good sale DI I think I might have to grab this! Thanks.
Reply 0
Oct 19, 2011 | 08:55 AM
  #47
This week's Weekly Special is DI Microfiber Waffle Weave Drying Towel.
Use Coupon Code WSWAFFL4211 to receive it for Free. A $17.99 value! Min spend $65. Offer ends 10/25/11 at 11:59 PM EST.
  • One of the best options for drying your vehicle and most commonly used by professional detailers
  • The waffle weave texture helps pull contamination away from the surface compared to a flat chamois
  • Our microfiber waffle weave towel has silk edging to minimize adding imperfections
  • This towel can hold up to 5 times its weight with water
  • We recommend using the sheeting method prior to drying with the towel for maximum efficiency
  • Always wash your microfiber products prior to first use
Reply 0
Oct 26, 2011 | 08:43 AM
  #48
This week's Weekly Special is TUF SHINE Tire Appearance Kit.
Use Coupon Code WSTIREA4311 to receive it for Free. A $39.99 value! Min spend $160. Offer ends 11/1/11 at 11:59 PM EST.
  • The first ever semi-permanent tire dressing that looks amazing and truly lasts
  • One coat rich and dark finish, two or more coats is extremely glossy
  • Contains no oils or silicone's that can harm the tire
  • Will not sling off, dries to the touch in minutes and applies with ease
  • Tires look stunning and do not feel greasy or oily at all
Reply 0
Nov 2, 2011 | 09:22 AM
  #49
This week's Weekly Special is Black WOW Black WOW - 4 oz.
Use Coupon Code WSBLACK4411 to receive it for Free. A $24.99 value! Min spend $170. Offer ends 11/8/11 at 11:59 PM EST.
  • Restore faded and neglected trim pieces, while leaving behind a bold even finish
  • Removes product residue from trim and lasts through multiple washes
  • Only a tiny bit of product is needed, use sparingly
Reply 0
Nov 9, 2011 | 08:47 AM
  #50
This week's Weekly Special is DI Brushes Lambs Wool Duster.
Use Coupon Code WSLAMBS4511 to receive it for Free. A $11.99 value! Min spend $25. Offer ends 11/15/11 at 11:59 PM EST.
  • Click product for complete description
Reply 0
Nov 16, 2011 | 08:33 AM
  #51
This week's Weekly Special is Meguiar's Ultra-Cut Compound M105 - 32 oz.
Use Coupon Code WSULTRA4611 to receive it for Free. A $26.99 value! Min spend $225. Offer ends 11/22/11 at 11:59 PM EST.
  • Very effective at cutting through deeper imperfections
  • Finishes down nicely, but we still recommend a finishing polish after 105
  • Commonly used with an orange light cutting pad, yellow cutting pad or purple foamed wool pad
Reply 0
Nov 23, 2011 | 08:39 AM
  #52
This week's Weekly Special is Einszett 1Z Cockpit Premium - 500 ml.
Use Coupon Code WSCOCKP4711 to receive it for Free. A $10.99 value! Min spend $60. Offer ends 11/29/11 at 11:59 PM EST.
  • One of the best interior cleaners and protectants that leaves your finish factory new
  • Easy to get streak free results every time, great scent, and UV protects
  • Best used on your dash, gauge cluster, navigation screens, audio components, shift *****, arm rests, leatherette, steering wheels and much more
Reply 0
Dec 1, 2011 | 03:05 PM
  #53
This week's Weekly Special is P21S Total Auto Wash - 1000ml Refill.
Use Coupon Code WSTOTAL4811 to receive it for Free. A $15.99 value! Min spend $85. Offer ends 12/6/11 at 11:59 PM EST.
  • One of the most versatile products we offer, degrease nearly any surface safely and effectively
  • Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
  • Can be used at full strength or diluted down to clean more delicate surfaces
  • Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
  • A must have any detailing enthusiasts or pro detailers arsenal of products
Reply 0
Dec 7, 2011 | 09:01 AM
  #54
This week's Weekly Special is Menzerna Super Intensive Polish SI 1500 (PO83) .
Use Coupon Code WSSUPER4911 to receive it for Free. A $29.99 value! Min spend $185. Offer ends 12/13/11 at 11:59 PM EST.
  • Most noted for its ability to easily remove imperfections, good work time, easy removal process and brilliant finish
  • You will instantly notice more gloss and depth with just one application
  • Can be applied by hand but optimal results are with a buffer and an Orange or Cyan Light Cutting Pad from Lake Country
  • A premium medium to heavy cutting polish removing visible surface imperfections while finishing down remarkably well
Reply 0
Dec 14, 2011 | 08:49 AM
  #55
This week's Weekly Special is P21S Total Auto Wash - 1000 ml Kit.
Use Coupon Code WSTOTAL5011 to receive it for Free. A $17.99 value! Min spend $95. Offer ends 12/20/11 at 11:59 PM EST.
Reply 0
Dec 21, 2011 | 09:01 AM
  #56
This week's Weekly Special is Meguiar's Professional Masking Tape - 1.5.
Use Coupon Code WSPROFE5111 to receive it for Free. A $4.50 value! Min spend $25. Offer ends 12/27/11 at 11:59 PM EST.
  • Properly protect trim, emblems, lights, adjacent panels and more when polishing or using a buffer
  • Instantly sticks on surfaces and releases quickly and cleanly without residue left behind
  • Perfect for protecting clear bra edges so you don't get product build up that shows
Reply 0
Dec 28, 2011 | 09:01 AM
  #57
This week's Weekly Special is Chemical Guys Black on Black - 11 oz.
Use Coupon Code WSBLACK5211 to receive it for Free. A $12.99 value! Min spend $50. Offer ends 1/3/12 at 11:59 PM EST.
  • One of the most unique trim restorers that turns faded trim back to a deep factory black finish
  • Perfect option for wheel wells, engine bay dressing, tire dressing and exterior trim pieces
  • Formerly referred to as Chemical Guys Fade 2 Black
Reply 0
Jan 4, 2012 | 08:30 AM
  #58
This week's Weekly Special is Meguiar's Ultra Finishing Polish M205 - 32 oz.
Use Coupon Code WSULTRA0112 to receive it for Free. A $27.99 value! Min spend $205. Offer ends 1/10/12 at 11:59 PM EST.
  • Removes swirls and light imperfections on any type of paint
  • Finishes down haze, hologram and marring free
  • Perfect follow up to Meguiar's Ultra Cut Compound 105
  • Commonly used with a white polishing pad or a black finishing pad
Reply 0
Jan 11, 2012 | 09:48 AM
  #59
This week's Weekly Special is Chemical Guys Extreme EZ-Creme Glaze with Acrylic.
Use Coupon Code WSEXTRE0212 to receive it for Free. A $16.99 value! Min spend $80. Offer ends 1/17/12 at 11:59 PM EST.
  • The perfect prep step before applying a sealant to enhance the gloss and depth of any color paint, while hiding minor imperfections
  • The acrylic based formula makes it compatible with both sealants and waxes
  • Best applied with a foam applicator pad as thin as possible and removed with a microfiber towel
  • When using a buffer, best applied with a black finishing pad
Reply 0
Jan 18, 2012 | 08:31 AM
  #60
This week's Weekly Special is 303 Aerospace Protectant - 16 oz.
Use Coupon Code WSAEROS0312 to receive it for Free. A $12.99 value! Min spend $60. Offer ends 1/24/12 at 11:59 PM EST.
  • An excellent UV protectant and dressing for vinyl, leather, rubber and plastic surfaces
  • Leaves behind a beautiful matte finish that is not greasy, shiny or oily
  • Treated surfaces resist dust, soiling, staining and also repel water
  • Most commonly used on interior dashboards, center consoles, door trim, leather seats, and in the engine bay
  • Works great on vinyl convertible tops, plastic rear windows, clear bras, and tonneau covers
  • For maximum efficiency use in a 4oz pump spray bottle and apply with a microfiber towel
Reply 0
