This week's Weekly Special is SONAX Wheel Cleaner Full Effect - 500 ml.
Use Coupon Code WSWHEEL3112 to receive it for Free. A $15.99 value! Min spend $70. Offer ends 8/7/12 at 11:59 PM EST.
- Sprays on fluorescent green and changes to a deep red as it reacts with contaminants on your wheel
- Extra strong wheel cleaner that is very gentle and pH neutral
- Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
- The 500ml bottle's spray nozzle provides a fine mist and steady stream which helps conserve product
- A premium wheel cleaner professional detailers absolutely love
Use Coupon Code WSWHEEL3512 to receive it for Free. A $15.99 value! Min spend $85. Offer ends 9/4/12 at 11:59 PM EST.
This week's Weekly Special is Stoner Invisible Glass - 19 oz.
Use Coupon Code WSINVIS3912 to receive it for Free. A $5.99 value! Min spend $25. Offer ends 10/2/12 at 11:59 PM EST.
- Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
- Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
- Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
- Do not apply in direct sunlight or hot glass, otherwise streaking may occur
This week's Weekly Special is DI Accessories Medium Grade Clay Bar - 100 g.
Use Coupon Code WSMEDIU4012 to receive it for Free. A $10.99 value! Min spend $30. Offer ends 10/9/12 at 11:59 PM EST.
- Use to remove stubborn contamination such as tree sap, tar, rail dust and paint overspray
- Large enough to break into several pieces for multiple uses
- We recommend Dodo Juice Born Slippy as a clay lube
- If you drop a piece of clay, throw it away!
This week's Weekly Special is Menzerna Paint Refresh Professional Grade Detail.
Use Coupon Code WSPAINT4112 to receive it for Free. A $23.99 value! Min spend $100. Offer ends 10/16/12 at 11:59 PM EST.
- Cleans, shines, and protects your paint all in one step
- Safe for painted surfaces, glass, plastic, chrome, etc.
- Quickly removes dust, dirt, fingerprints, and light contamination
- Leaves behind a layer of protection and anti-static properties
This week's Weekly Special is Brinkmann Maxfire Dual Xenon Swirl Finder.
Use Coupon Code WSMAXFI4212 to receive it for Free. A $29.99 value! Min spend $190. Offer ends 10/23/12 at 11:59 PM EST.
- Easily reveal swirls, scratches and other imperfections with this lightweight rechargeable hand held spotlight
- Avoid having to use bulky, corded, and hot halogen light stands!
- Get the best polishing results with the proper lighting, no guess work if imperfections have been removed effectively
This week's Weekly Special is Chemical Guys Black on Black - 11 oz.
Use Coupon Code WSBLACK4312 to receive it for Free. A $12.99 value! Min spend $60. Offer ends 10/30/12 at 11:59 PM EST.
- One of the most unique trim restorers that turns faded trim back to a deep factory black finish
- Perfect option for wheel wells, engine bay dressing, tire dressing and exterior trim pieces
- Formerly referred to as Chemical Guys Fade 2 Black
This week's Weekly Special is P21S Gel Wheel Cleaner - 500ml Kit.
Use Coupon Code WSGELWH4412 to receive it for Free. A $17.99 value! Min spend $85. Offer ends 11/6/12 at 11:59 PM EST.
- One of the safest, most effective, pH balanced wheel cleaners on the market
- Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
- Perfect option for after market wheels as it is safe for virtually any wheel surface
- Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
- Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
This week's Weekly Special is Stoner Tarminator - 10 oz.
Use Coupon Code WSTARMI4512 to receive it for Free. A $5.99 value! Min spend $25. Offer ends 11/13/12 at 11:59 PM EST.
- Safely and effectively remove tar, grease and sap from painted surfaces
- Simply spray Tarminator onto the effected area, let dwell for a minute or two, then wipe clean
- Remember to protect the areas you use Tarminator on with a sealant or wax
This week's Weekly Special is DI Accessories Sheepskin Wash Mitt without thumb.
Use Coupon Code WSSHEEP4612 to receive it for Free. A $10.99 value! Min spend $65. Offer ends 11/20/12 at 11:59 PM EST.
- All natural fibers makes it one of the safest wash mitts on the market
- The natural fibers help pull contamination away from the surface without harming even the most delicate finishes
- When done rinse any contamination away using free flowing water than hang dry with leather loop
- Can be used with any shampoo or rinseless wash (i.e. Optimum No Rinse Wash & Shine New Formula (ONR))
This week's Weekly Special is Collinite 845 Insulator Wax - 16 oz.
Use Coupon Code WSINSUL4712 to receive it for Free. A $15.99 value! Min spend $80. Offer ends 11/27/12 at 11:59 PM EST.
- A liquid carnauba wax that will keep your car protected like a sealant!
- Very easy to apply and remove
- Incredible levels of gloss that dramatically improves any color paint
- Repels water, pollution, sun, salt, bugs and more
- Can be applied to virtually any exterior finish
This week's Weekly Special is Gilmour Power Flow Hose Nozzle.
Use Coupon Code WSPOWER4812 to receive it for Free. A $18.99 value! Min spend $60. Offer ends 12/4/12 at 11:59 PM EST.
- High pressure hose nozzle that offers plenty of power!
- Excellent nozzle that fits on any hose
- Top quality parts make this durable nozzle a great investment
- Offers tons of power or a fine mist and everything in between
Use Coupon Code WSGELWH4912 to receive it for Free. A $17.99 value! Min spend $95. Offer ends 12/11/12 at 11:59 PM EST.
This week's Weekly Special is Leatherique Prestine Clean - 16 oz.
Use Coupon Code WSPREST5012 to receive it for Free. A $19.99 value! Min spend $105. Offer ends 12/18/12 at 11:59 PM EST.
- A premium leather cleaner with light conditioners, perfect for cleaning and maintaining leather
- Restores proteins that are naturally found in leather for a soft and supple feel
- Completely matte finish that has no greasy or oily residue
- Apply to your leather and let sit for 15 - 30 minutes, wipe with a warm damp towel and wipe dry with a second towel
- For maximum results, Prestine Clean is best used after Leatherique Rejuvenator Oil
This week's Weekly Special is DI Microfiber Autofiber Zero Edge Towel - 16".
Use Coupon Code WSAUTOF5212 to receive it for Free. A $4.99 value! Min spend $20. Offer ends 1/1/13 at 11:59 PM EST.
- Highly effective edgeless design saves you time while improving results
- Premium microfiber threads that feel extremely soft
- Specializes in removing the left over product (i.e. polish, wax, etc.) from the paint
- Very durable design that can be machine washed
- Can be used for virtually any detailing task
