New FREE Car Care Product every week at DetailedImage.com
Old May 1, 2013 | 08:22 AM
  #121
Detailed Image's Avatar
This week's Weekly Special is Sonax Wheel Cleaner Full Effect - 500 ml.
Use Coupon Code WSWHEEL1813 to receive it for Free. A $15.99 value! Min spend $70. Offer ends 5/7/13 at 11:59 PM EST.
  • Sprays on fluorescent green and changes to a deep red as it reacts with contaminants on your wheel
  • Extra strong wheel cleaner that is very gentle and pH neutral
  • Safe on chrome, alloy, anodized, stainless steel, clear coat and polished wheels
  • The 500ml bottle's spray nozzle provides a fine mist and steady stream which helps conserve product
  • A premium wheel cleaner professional detailers absolutely love
Old May 8, 2013 | 08:28 AM
  #122
This week's Weekly Special is P21S Gel Wheel Cleaner - 500ml Kit.
Use Coupon Code WSGELWH1913 to receive it for Free. A $17.99 value! Min spend $95. Offer ends 5/14/13 at 11:59 PM EST.
  • One of the safest, most effective, pH balanced wheel cleaners on the market
  • Gel based formula allows the product to penetrate vertical surfaces for a more effective cleaning
  • Perfect option for after market wheels as it is safe for virtually any wheel surface
  • Works best when an E-Z Detail Brush is used in conjunction with P21S Gel Wheel Cleaner
  • Follow up with Poorboy's World Wheel Sealant for wheels that are easier to maintain
Old May 15, 2013 | 08:19 AM
  #123
This week's Weekly Special is P21S Total Auto Wash - 1000 ml Kit.
Use Coupon Code WSTOTAL2013 to receive it for Free. A $17.99 value! Min spend $70. Offer ends 5/21/13 at 11:59 PM EST.
  • One of the most versatile products we offer, degrease nearly any surface safely and effectively
  • Use on paint, trim, rubber, vinyl, carpets, plastic, glass, leather and many other surfaces
  • Can be used at full strength or diluted down to clean more delicate surfaces
  • Used by many high end detailers to properly prep surfaces for polishing, restoring or protecting
  • A must have any detailing enthusiasts or pro detailers arsenal of products
Old May 22, 2013 | 08:13 AM
  #124
This week's Weekly Special is Collinite 126 Auto Cleaner Wax - 16 oz.
Use Coupon Code WSAUTOC2113 to receive it for Free. A $14.99 value! Min spend $110. Offer ends 5/28/13 at 11:59 PM EST.
  • Will clean and protect your paint while leaving behind an amazing gloss!
  • Easy to apply by hand or with a buffer
  • Durable protection that truly lasts
  • Excellent All In One (AIO) product that polishes and waxes in one step
Old May 29, 2013 | 08:40 AM
  #125
This week's Weekly Special is DI Accessories Detailed Image Kneeling Pad - 12 inch x 12 inch .
Use Coupon Code WSDETAI2213 to receive it for Free. A $5.99 value! Min spend $35. Offer ends 6/4/13 at 11:59 PM EST.
  • Use it as a kneeling pad or as a seat cushion
  • It's weatherproof and durable!
  • Thin design yet very strong for great support
  • Proudly display your love of Detailed Image!
Old Jun 5, 2013 | 08:26 AM
  #126
This week's Weekly Special is DI Accessories Fine Grade Clay - 100 g.
Use Coupon Code WSFINEG2313 to receive it for Free. A $10.99 value! Min spend $20. Offer ends 6/11/13 at 11:59 PM EST.
  • Safely remove road grime, brake dust, tar, sap, paint over spray and more
  • Fine grade clay bars are gentle on your exterior paint
  • We recommend using Dodo Juice Born Slippy or Poorboy's World Spray & Wipe as your clay lube
  • Can be used on brand new cars to older vehicles with light to medium build ups
Old Jun 12, 2013 | 08:15 AM
  #127
This week's Weekly Special is Einszett Gummi Pflege Stift Rubber Care Stick - 100 ml.
Use Coupon Code WSGUMMI2413 to receive it for Free. A $8.99 value! Min spend $45. Offer ends 6/18/13 at 11:59 PM EST.
  • Restore and care for rubber trim and seals to keep them elastic and looking like new
  • Protects against extreme temperature and UV rays
  • Shoe polish like applicator makes the application extremely easy and smooth
Old Jun 19, 2013 | 08:26 AM
  #128
This week's Weekly Special is Stoner Invisible Glass - 19 oz.
Use Coupon Code WSINVIS2513 to receive it for Free. A $5.99 value! Min spend $30. Offer ends 6/25/13 at 11:59 PM EST.
  • Foam based glass cleaning formula that is ammonia free, making it safe on tinted windows
  • Easily removes oily dirt, dust, fingerprints, grease, adhesives, smudges, smoke haze and more from glass
  • Best applied with an all purpose microfiber towel, then wiped clean with a dry low nap microfiber towel
  • Do not apply in direct sunlight or hot glass, otherwise streaking may occur
Old Jun 26, 2013 | 08:44 AM
  #129
This week's Weekly Special is Dodo Juice Hard Candy Hard Wax - 30 ml.
Use Coupon Code WSHARDC2613 to receive it for Free. A $9.99 value! Min spend $55. Offer ends 7/2/13 at 11:59 PM EST.
  • A Dodo Juice hard carnauba wax designed to work on any colored vehicle, light or dark
  • Extremely easy to apply and remove, especially when applied in thin layers
  • Strong protection and tight water beading makes maintaining your vehicle a breeze afterwards
  • Dodo Juice hard waxes offer slightly more durability than the Dodo Juice soft waxes
  • Apply with a foam applicator pad and remove with a plush microfiber towel
Old Jul 3, 2013 | 04:05 PM
  #130
Use Coupon Code WSGELWH2713 to receive it for Free. A $17.99 value! Min spend $75. Offer ends 7/9/13 at 11:59 PM EST.
Old Jul 10, 2013 | 09:30 AM
  #131
This week's Weekly Special is 3M Automotive Masking Tape - 18 mm.
Use Coupon Code WSAUTOM2813 to receive it for Free. A $2.99 value! Min spend $25. Offer ends 7/16/13 at 11:59 PM EST.
  • Quality masking tape for protecting your trim, paint and more!
  • Instantly sticks on surfaces and releases quickly and cleanly without residue left behind
  • Great value!
Old Jul 24, 2013 | 08:44 AM
  #132
Use Coupon Code WSTOTAL3013 to receive it for Free. A $17.99 value! Min spend $95. Offer ends 7/30/13 at 11:59 PM EST.
Old Jul 31, 2013 | 08:09 AM
  #133
Today's Daily special (July 31, 2013) is Blackfire Wet Diamond Polymer Spray.
Regular Price for 20 oz is $19.99. Today's price is $14.79!
  • An amazing quick detailer that not only enhances the gloss and depth but adds significant protection
  • Looks outstanding and works great on top of the Blackfire Wet Diamond All Finish Paint Protection
  • We recommend applying it to a freshly cleaned surface
  • Can be applied on top of any sealant or wax
You can receive email notifications of our Daily Special each morning by signing up for a Detailed Image account
Old Jul 31, 2013 | 08:37 AM
  #134
This week's Weekly Special is P21S Gel Wheel Cleaner - 1000 ml.
Use Coupon Code WSGELWH3113 to receive it for Free. A $22.99 value! Min spend $120. Offer ends 8/6/13 at 11:59 PM EST.
Old Aug 7, 2013 | 08:36 AM
  #135
This week's Weekly Special is Einszett ColourTec Wheel Cleaner - 16.9 oz.
Use Coupon Code WSCOLOU3213 to receive it for Free. A $13.99 value! Min spend $45. Offer ends 8/13/13 at 11:59 PM EST.
  • Extra strong and effective wheel cleaner that is very gentle and non-corrosive
  • This product changes colors after it breaks down select contaminants
  • A premium wheel cleaner professionals and enthusiasts will absolutely love
