Menzerna 25% OFF (exp 5/17) Plus our Weekly Special & Monthly Specials
Old May 11, 2011 | 05:36 PM
Detailed Image's Avatar
25% OFF MENZERNA
The entire line of Menzerna products is on sale through 5/17 no coupon codes needed. Check out all the Menzerna products and sale prices here. So that means you can still use your forum discount code to save 10% off on other items, however please remember it does not apply to sale items, tools and DI Packages. Another option is you can use our Weekly Special coupon code listed below.
Weekly Special (exp 5/17)
This week's Weekly Special is Optimum Instant Detailer & Gloss Enhancer - 17.
Use Coupon Code WSINSTA1911 to receive it for Free. A $9.99 value! Min spend $65. Offer ends 5/17/11 at 11:59 PM EST.
  • An outstanding quick detailer that enhances gloss and depth while increasing surface slickness
  • Easy to apply and remove streak free by misting into a plush microfiber towel and wiping your paint
  • Most commonly used after washing and drying your vehicle as a maintenance product
  • The 32oz and 128oz sizes are concentrated formulas to get even more bang for your buck
May Monthly Specials
Special # 1 - DI Microfiber Waffle Weave Drying Towel
Regular Price for 36" x 24" is $17.99. Sale price is $12.99!
  • One of the best options for drying your vehicle and most commonly used by professional detailers
  • The waffle weave texture helps pull contamination away from the surface compared to a flat chamois
  • Our microfiber waffle weave towel has silk edging to minimize adding imperfections
  • This towel can hold up to 5 times its weight with water
  • We recommend using the sheeting method prior to drying with the towel for maximum efficiency
  • Always wash your microfiber products prior to first use
Special # 2 - Poorboy's World Natty's Blue Paste Wax
Regular Price for 8 oz is $19.99. Sale price is $14.99!
  • Arguably, the best carnauba paste wax for darker colored vehicles for under $20
  • Leaves behind a ton of depth and gloss, especially when multiple coats have been applied
  • Easy to apply and remove with a foam applicator pad and a microfiber towel for removal
  • An 8 oz jar will two dozens application when applied correctly
If you need any recommendations or if you have any questions don't hesitate to ask!
Greg @ DI
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
Team STILLEN
Aug 10, 2015 08:17 PM
