bryansbestwax vs black Acura NSX
This was a new customer to me. He had done some research, and decided I might be the guy to help out his NSX look better. The car was in fairly bad shape, lots of swirls and scratches. We had talked on the phone and decided with a single step polish this time. After looking at the damage, I changed it up a bit and chose a bit stronger approach, that required 2 steps. He also wanted a coating done to the car and so I applied Opti coating.
This detail was also done on the hottest day of the year, 130+ degrees outside with the humidity.
The Process
Wheels cleaned with AM Magnificent
Tires cleaned with AG CWC
Presoaked with APC
Washed with Werkstat Auto Body Wash
Polished with SIP then Super finish via a DA
Washed again with Werkstat mixed with APC
Wiped down with Pre Paint Cleaner
Applied Opticoating
The before
Inside After the wash and Stripping of wax
After polishing
Outside shots
Thanks for looking
The Process
Presoaked with APC
Applied Opticoating
The before
After polishing
Outside shots
Thanks for looking
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
