WHEEL DUST!!!!
Old Apr 30, 2003 | 07:07 PM
DaGS1800's Avatar
WHEEL DUST!!!!
How the F*%$# do you clean the F*%# ing wheel dust good? this car produces the most wheel dust ive ever seen..... How exactly do you clean this good?
Old Apr 30, 2003 | 08:20 PM
Merlin's Avatar
Staff ALUMNI
Re: WHEEL DUST!!!!
Some of us take the time and clean it really good then wax them. From then on they are easier to clean, but you will have to wax about every other month or more depending on how **** retentive you wan to be.[img]/w3timages/icons/crazy.gif[/img]
Old Apr 30, 2003 | 09:20 PM
Scoop's Avatar
Re: WHEEL DUST!!!!
If you don't use your brakes there should be little or no brake dust .
just be very careful hahahaha
<font color=blue>[b]G35c DG/leather 5AT 18"wheels Tint.... The car in your mirror will fade quickly
Old May 1, 2003 | 02:00 AM
ryoken's Avatar
Re: WHEEL DUST!!!!
And when it comes time to replace your front pads, look into some aftermarket options instead of getting another set of OEM pads. There are EBC GreenStuff and Hawk HPS part numbers floating around these forums somewhere. Both are supposed to provide similar or better performance with a fraction of the brake dust.
Old May 1, 2003 | 10:56 AM
AfroCreame's Avatar
Re: WHEEL DUST!!!!
Piece of cake...go and buy "Simple Green" at Wal-Mart or auto parts store....spray on the rims, powerwash off...spotless.
Old May 1, 2003 | 06:14 PM
DaGS1800's Avatar
Re: WHEEL DUST!!!!
The problem is that they sqeek very loudly when brake dust builds up how to I get rid of the sqeeking, and wat exactly do i clean and with wat, the wheels are not wat i care about its the brakes cause the still sqeek with new break pads......
Old May 1, 2003 | 08:47 PM
ryoken's Avatar
Re: WHEEL DUST!!!!
You can get rid of brake dust on the rotors (and get rid of the squeaking it causes) by braking HARD a few times. A couple of really brisk 30-0's will clean the rotors right up. Moderate braking won't allow the buildup. Light braking will.
I'm not sure what the pads are made of, though.. and if they're semi-metallic, you can't completely eliminate the squeal.
Old May 3, 2003 | 12:11 AM
SKYL1NE's Avatar
Re: WHEEL DUST!!!!
Put EBC Green on my Coupe when it only had about 300 miles. I have not had to clean my wheels again in between washings. They are great.
AlanL :-)
Old May 3, 2003 | 12:44 AM
ryoken's Avatar
Re: WHEEL DUST!!!!
Did you do any hard stops before and after installing the GreenStuff pads? How do they compare in stopping power?
Old May 3, 2003 | 03:40 PM
chinee's Avatar
Re: WHEEL DUST!!!!
How long have they been on? Miles and days.... How's the braking performance in comparison?
03 G35
02 Sequoia
Old May 17, 2003 | 06:55 PM
Msedanman's Avatar
O.F. Administrator
Re: WHEEL DUST!!!!
Tell us about your EBC Green pads bro. How much they are, where bought, and how they compare to stock. Thanks
<font color=green>GSM</font color=green>
Old May 17, 2003 | 07:32 PM
Merlin's Avatar
Staff ALUMNI
Re: WHEEL DUST!!!!
Part number for the front and rear would be nice or did I miss those.[img]/w3timages/icons/blush.gif[/img]
Old May 19, 2003 | 05:24 AM
ryoken's Avatar
Re: WHEEL DUST!!!!
Merlin: I guess you missed them. (But they were in a different thread...) [img]/w3timages/icons/smile.gif[/img]
EBC Greenstuff brake pad availability
<hr>Posted by Marty:
Greenstuff pads are now available: front only
http://www.brakesrus.com/greenstuffcat.html
G35 2003 Front DP21636 $79.00 Will Fit Sedan , Will fit coupe but not if you have the brembo caliper upgrade.
TireRack also carries EBC pads, but they're not listed on their site yet.
<hr>
Old May 19, 2003 | 08:16 PM
Merlin's Avatar
Staff ALUMNI
Re: WHEEL DUST!!!!
Thanks Ryo,
Knew we made you a Mod for a reason.[img]/w3timages/icons/smile.gif[/img]
Old May 20, 2003 | 02:21 AM
Daniele's Avatar
Re: WHEEL DUST!!!!
Put some elbow grease into it!! No, really if you wash your wheels about once a week the brake dust comes off so easily. Oh, and Wheel Wax is awesome stuff. If you live in the states you can get it at Discount tire (or online). It'll get off anything that's really stuck on and keep them cleaner longer. Oh- and if you use any sort of tire shine, make sure you get ALL of the excess of the tires cause when you start driving it'll spray onto the wheels and it is a dust magnet.
