Headlight scratch removal
Old Dec 13, 2013 | 05:52 PM
Air_Infiniti's Avatar
Hey guy, Im trying to find a way to remove the scratches on my headlight lens the only way i can find is sanding it and buffing it. However im not sure how well that will work therefore i was wondering if any of you have done it and can give me some advice or maybe a different method to remove the scratches.
Old Dec 13, 2013 | 06:16 PM
Urbanengineer's Avatar
I wonder this too, and then i used the search feature to find many, many answers.
It seems wet sanding 1500-2500-4000 works best to remove scratches, but cannot fix cracks. FROM HERE YOU MUST seal the headlight with plastic sealant or wax it and prepare to sand next year.
Old Dec 15, 2013 | 07:24 PM
OldManRivers's Avatar
http://www.chemicalguys.com/Chemical...flex_443_9.htm
When finished use a coat of chemical guys Jetseal 109
Old Dec 15, 2013 | 10:51 PM
Thank you, I have been looking for a better sealant.
Sanding every 2 years is still 2 much
Old Dec 15, 2013 | 11:36 PM
904gfromfl's Avatar
Depends how deep the scratches are. Start off with wet sanding 1200 to 1500 final 2000. Use rubbing compound to clean it up
Old Dec 15, 2013 | 11:37 PM
904gfromfl's Avatar
Wet sand with 1200 to 1500 & finally 2000. Use rubbing compound to clean it up
Sepsis
Feb 12, 2020 02:05 PM
aktif8
2nd Gen (V36) Sedan
30
Aug 5, 2017 11:47 PM
PrestigeG35
Sep 21, 2015 10:10 AM
Mick_L
Aug 25, 2015 04:27 PM
Ray Feta
Aug 20, 2015 08:46 PM
