Remove Clear Bra Protection From Rear Quarter Panels ?
Old Apr 10, 2015 | 02:51 PM
digital sol's Avatar
I have a DG 04 g35 coupe and it has some clear bra panels patches in certain areas on the vehicle.
-front fender behind wheel
-rear quarter panel before the wheel base
The front ones look fine they are still clear however the ones on the rear quarter panel right before the wheel base look very scratched up. If you get close enough you see tiny scratches all over them and they don't feel smooth. I would like to remove these and just wax the entire area.
What's the best way to go about removing these? I am being very cautious because I removed vinyl from the hood on this vehicle and it took the clear coat with it. Apparently infinti has stoooopid soft and delicate paint.
Thanks fellas!
Old Apr 16, 2015 | 05:04 AM
jrandys's Avatar
You can use steam or adhesive remover like 3M and a plastic razor blade. It takes some patience to totally remove the clear bra.
tiguy99
Mar 1, 2016 11:42 AM
