Newb needs help! (Zaino related)
Old May 4, 2005 | 02:42 AM
socalg35's Avatar
Originally Posted by wreck
That's a good kit, but if you want to save some money I would just get.
ZFX™ Flash Cure Accelerator Additive
Z-2 PRO™ Show Car Polish for Clear Coated Car Finishes
Z-6™ Ultra Clean Gloss Enhancer Spray
You don't need Z-5 (yet) and the Clay Bar if you take care of your car. If you have a dark colored car, then definitely get the Z-5 to hide the swirl marks.
MF towels are needed to wash you car. Also to remove the polish from your car. Don't use anything else (including the ones that come with the kit. Use those to gloss your tires . The applicator is used to apply Z-2 on your car.
Zainos tip:
#1 Less is more. Apply very little. Sometimes when I apply Zainos, I can barely see the haze.
#2 When mixing the accelerator I use a BIG Syringe. Those little bottles that come with it, are a pain. With a syringe you can use ever bit of Zainos mixed.
Microfiber products can be purchased from the net. I've tried many different companies MF products and the best one so far is Vipers Microfiber products. They are thicker than the lower priced microfiber products from other vendors. Where I get my Microfiber Stuff
Where'd you pick up the syringe?
Old May 4, 2005 | 01:14 PM
Calypsi's Avatar
Scientific supply places sell syringes like here although I dont know if 50cc is big enough cc = approx a mL
http://www.vwrsp.com/catalog/product...44&resultNum=8
and actually after looking at that make sure you check that it is plastic, syringes can come in alot of forms, like glass or metal also. If ya serch the site though you should be able to find something that will work for ya, just make sure its plastic with no needle attached.
Marlin84
Apr 1, 2020 12:52 PM
Row2k
Drivetrain
Dec 27, 2015 04:08 PM
Blue Dream
Dec 5, 2015 10:56 AM
doakley92
Sep 25, 2015 12:58 PM
