Cant find the 2 step scratch remover..
Old Sep 28, 2005 | 05:52 PM
STill_matic's Avatar
Someone posted a link to a really good 2 step scratch remover. I think whoever posted it was affiliated with the website that sold it. I tried searching but can't find it.
update:
-found it here:
https://g35driver.com/forums/care-detailing/65154-help-needed-debadging-problem.html
Old Sep 29, 2005 | 10:28 AM
Punchit's Avatar
That was me and I responded to your PM. The two step scratch remover your looking for is the Poorboy's World Super Swirl Remover 2.5 followed by the Super Swirl Remover 1.0. These two products used in combination by hand or with an orbital buffer (PC) can produce tremendous results. The SSR 2.5 does the heavy cutting and reduces heavy swirls and scratches. The SSR 1.0 is great for removing any fine scrathces after and restoring a glossy finish to the surface. After using these two products though there is no wax or sealant left on the vehicle. Therefore I always recommend applying a good sealant and topping it off with a good carnauba wax after.
Old Sep 29, 2005 | 11:15 AM
Picus's Avatar
Staff ALUMNI
Just be careful with 2.5 by hand. You need to really work it to remove scratches and not produce more. It's really much better by PC, but if you do use it by hand just use it on a small area and make sure to work it in until it goes clear or dusts, otherwise you'll just end up with more scratches.
shavedcrx
18 Inch
Dec 29, 2015 07:39 AM
derres
Aug 28, 2015 03:27 PM
RAVSPEC
Wheels & Tires-Vendor
Aug 21, 2015 06:03 PM
