Touching up scuff on side mirror casing
Old Oct 6, 2005 | 09:45 AM
reisende's Avatar
Question Touching up scuff on side mirror casing
Hi everybody.
I just noticed that I've got what appears to be a quarter sized scuff on the top of the plastic casing of my driver's side mirror. It has scuffed off the top layer of the black plastic to the white below it.
Can anybody suggest something to use to cover that up? It's a minor thing, but it is annoying as hell. I imagine it would be a little easier to cover up than if it was on the body paint, but I'm not sure.
Thanks.
Old Oct 6, 2005 | 11:50 AM
Picus's Avatar
Staff ALUMNI
If the plastic is down that far you might need to have it replaced. Someone else might have an idea, but aside from re-painting it yourself (which will probably look terrible), I can't think of anything.
It would actually be easier to touchup on the paint, since you could touchup, wetsand, then polish.
Old Oct 7, 2005 | 02:45 PM
reisende's Avatar
Really, the paint would be easier? I was afraid it would probably require replacing. The good thing is is that it's on the inside, closer to the car so it isn't noticeable unless you're looking for it.
Thanks for the reply picus.
Old Oct 7, 2005 | 08:41 PM
maxpower's Avatar
Originally Posted by reisende
Hi everybody.
Thanks.
if you are talking about the black plastic piece that holds the mirror, I would try a black sharpie or magic marker to cover the white. you may have to wipe with a rag and use a few coats to get it to blend into the rest of the black plastic.
Ludz
Lights
Mar 28, 2016 02:06 AM
Kz_Ed
Jul 23, 2015 02:41 AM
.cakestar
Audio/Video/Electronics
Jul 17, 2015 08:22 PM
emorehs
Jul 17, 2015 09:45 AM
