Using a machine vs hand?
Old Jan 3, 2003 | 04:07 PM
pestilence's Avatar
Hey Guys... I was wondering for applying Klasse... or anything else on your car.. is it easier/better to use a machine or to do it by hand? I konw that doing it by machine would be easier.. but would it be better???? I was looking at the Porter Cable 7424 Polisher.
..pestilence..
Old Jan 5, 2003 | 02:09 PM
tec243's Avatar
Re: Using a machine vs hand?
pestilence, I've been using a Craftsman orbital buffer for years using only Meguire's yellow #26. It's easier for sure but I still have to apply/remove some areas i.e. curves, hard angles by hand. I still go over with a towel afterwards to catch anything missed and for that awesome tactile feeling of a freshly waxed surface. For the wide open spaces and smooth curves like on the G, I think the buffer will make quick work of your detail job. It's easier to be more consistent in protection application and removal with a machine. The PC 7424 seems to be the machine of choice. When mine breaks, that'll be the one I target. If you're new to exterior detailing, consider doing the work by hand a couple of times to know what kind of results to expect when you start using a machine. ...dean
Seattle area
Old Jan 5, 2003 | 03:46 PM
mstil35's Avatar
Deatailed my G35 this weekend, used the porter cable 7424 with a white foam pad to apply Klasse All-In-One and removed it by hand with a micro-fiber cloth. Applied the High Gloss Sealant Glaze by hand with a micro-fiber applicator pad and then buffed off the residue with the porter cable 7424 with a micro-fiber bonnet. LOOKS FANTASTIC!!!! Will probably put on another coat of High Gloss Sealant Glaze next weekend.
Old Jan 7, 2003 | 07:44 PM
pestilence's Avatar
Thanks for the info... I really want to get into exterior detailing of the G... to give it that awesome shine Klasse gives... *drool*
..pestilence..
Old Jan 15, 2003 | 07:59 PM
pestilence's Avatar
I think I read that its better to do curves (like the G has) by hand.. Is this correct? What has your experance been?
..pestilence..
Old Feb 6, 2003 | 03:08 PM
BlackFire's Avatar
Pest... I've also had my 7424 for some time. The only problems I've had are getting into corners where the machine wouldn't fit. Those are the places I do by hand. As long as you use the right pads, you should have no problem with the curves. Check out http://www.properautocare.com/porcabpolac.html for lots of 7424 accessories and "how to" steps.
Old Feb 6, 2003 | 06:19 PM
mstil35's Avatar
I agree with Blackfire....Used the Porter Cable 7424 over the entire car, including the bumpers and air dams/intakes in the bumper. Had no problem whatsoever, but I did keep a Micro-fiber polishing cloth hand just in case.
Old Feb 8, 2003 | 07:46 PM
ghom923's Avatar
Is the Porter Cable 7424 the one with a clutch to prevent paint/finish burning?
Old Feb 9, 2003 | 01:01 AM
mstil35's Avatar
It is a random orbital polisher so it is virtually impossible to burn paint if you use the foam pads. NEVER USE THE WOOL, it will cause serious swirls.I have never had a problem and have had mine for about 4 years.
Old Feb 9, 2003 | 01:15 AM
ghom923's Avatar
Thanks very much. I'm going to order one right now.
Old Feb 9, 2003 | 04:19 AM
IQ9's Avatar
IQ9
Pest, remember that you can always add a coat of carnuba wax after the Klasse. This will really add dept to the paint. I use Griots Garage carnuba. It has a really high wax content and the price is fair. I used to use Zymol Japon,way too expensive at $120 a tub. Keep the Klasse on and for extra pop hit with some carnuba(yellow wax). You can use it with machine or without. I also do use a wool pad on my buffer after I'm done but I use light pressure. It seems to even out the finish.
03.5 Sedan/B. Silver/Premium/Winter/Aero
69 Chevelle BB/4.11's
Old Feb 9, 2003 | 06:45 PM
Msedanman's Avatar
O.F. Administrator
I'm interested in a Porter Cable #7424, and found a Home Depot that sells them. Do they come with a selection of pads and applicators or are they sold separately?
Any other tips on the use of this polisher? thanks[img]/w3timages/icons/smile.gif[/img]
<font color=red>Gsedanman</font color=red>
Old Feb 9, 2003 | 06:48 PM
mstil35's Avatar
They are sold seperately. A good place to chec is www.properautocare.com. They carry all the pads as well as the PC 7424. You can even order a package that includes the buffer and several pads as well as the velcro faced backing pad. Prices are pretty good as well.
Old Feb 9, 2003 | 06:54 PM
Msedanman's Avatar
O.F. Administrator
Thanks dude, I'll check that out.........[img]/w3timages/icons/smile.gif[/img]
