Cars for Sale CDN Looking for a G35? No dealers, no exceptions.
FS[Canada]: Modified Sedan G35X
Old Feb 22, 2017 | 08:57 PM
g35xsleeper's Avatar
Modified Sedan G35X
Fully Loaded Infiniti g35x Modified Sedan
with:
3.5L V-6 Engine
5-spd auto w/OD Transmission
All wheel Drive , ABS and driveline Traction contro, Air Conditioning
Driver and front passenger heated seats, AM/FM stereo, seek-scan Radio Keyfob (all doors) Remote keyless entry, LED Fog/driving lights, Leather Seats with Driver Lumbar support. Car is Super Clean, I am the second owner, car has no accidents is in very good condition.
Wheels
• 19inch HRE staggered wheels (10.5inch rear and 9.5inch front) Summer Rims
• Michelin Pilot Sports 225/40/19 front tires, Bridgestone Potenza Run Flats 245/40/19 rear tires (also extra set of summer tires)
• A set of 18 MSR wheels Winter Rims with
• 225/50/19 Brand New Bridgestone Blizzaks for the Winter should last another 3-4seasons
• Just got a 4 wheel alignment
Brakes
• Akebono OEM 4 piston calipers front
• Akebono OEM 2 piston calipers rear
• OEM Japanese Spec Cross drilled & slotted zinc coated
• 14.7 inch front and 14.3 inch rear rotors
Engine
• Skunk2 plenum intake
• Skunk2 stage 2 cams
• Stillen OEM Ztube
• Stillen OEM stage 2 Map
• Nismo OEM Japanese spec headers
• Nismo OEM Japanese spec straight pipe
• HID ‎lights OEM Japanese spec
• Eibach progressive rate lowering springs
• Tein shocks - OEM Japanese spec
• Eibach camber kit (Front only)
• Nismo lower sway bars (Front and Rear - OEM Japanese spec)
• Also have a Nismo launch control, uninstalled (Can easily be re-installed again)
• Always synthetic oil changed every 5000kms
• All transmission fluid changed with authentic OEM Synthetic fluids 15,000kms
• Also comes with an Infiniti mechanic who has worked on car since new (also very inexpensive for all repairs)
Vehicle Maintenance
• OEM Japanese spec Titanium Plugs
• OEM Japanese spec Compliance bushings
• OEM All four wheel bearings
• OEM all bushings
• Front Drive Shafts & Boots
• Steering wheel bushing
• Front and Rear Drive shaft
• Upper control arms OEM front Driver & Passenger side
• Main drive belts
• All fluids changed to Synthetic OEM spec or better.
• A lot of other items all done ie. Throttle body cleanse, filters, etc.
