WTB: OEM Ignition Coil Packs
anyone local have some available for sale...I am now getting a cylinder misfire on my car and need to replace cylinder 2 coil pack.....I had the same issue last week in which my cylinder 1 was mis-firing...im not really sure why this is happening but I need a new set.
Let me know what your asking price is...or if you have any laying around that your willing to let me take!
Thanks
Thanks
You may need to change your spark plugs as they may have been fouled, or your fuel injectors could be dirty, or your fuel pump could be going bad. Did you open it up yet?
nope this all happened lastnight....this did this last week....my cylinder 1 coil pack was fried...had a huge bubble coming out of it..like it had melted..I had my fuel tank replaced alittle while back because of a leak and installed a new fuel pump then....
here you go...pulled my coil pack off first thing this morning......
Coilpack 1 - Bubble on the inside of it is fried.
Coilpack 2 - just pulled off and same bubble just not as big.
Sure enough my cylinder 2 coil pack is fried....not sure why this is happening..I am assuming I probably need to replace my spark plugs in my car and do a full tune-up today.
lol....to make it even worse Stephen...I figued out the problem.....change out all my spark plugs tonight and was putting the new coil packs back in and sure enough...the last damn coil I start screwing the bolt down..its going in fairly smooth and then all of sudden snap.....the freaking bolt that holds the coil pack on snapped in half...so now I have a broken bolt off in my valve cover...I have the reverse screw extractor..tried that and it wouldnt do anything.....
I would say I have a grimlin bud being that I snapped the damn coil pack bolt off in the valve cover....now I need to replace the valve cover.....wonderful....I should take them off and have you paint them.
no need to replace the valve cover. After im done at the shop we can see what we can do with it tomorrow. If all else fails we can pull the cover off. Drill it out and retap. It should be the standard 6mm x 1.0 thread
