Fs: Kicker L7 12" sub w/ kicker probox
Old Aug 9, 2010 | 05:52 PM
G!deRty!FizZiE's Avatar
for sale kicker L7 12" sub w/ ported probox and a Audiobahn (8000t) amp
Hard hitting subs, with a very high sound quality, a car audio enthusiast just couldn't ask for much more!
selling both items for 300.00
give me a text at 972-322-8950 thx..
here are the specs:Size 12"
Nominal Power Handling 750 Watt RMS
Technical Features
Peak Power Handling 1500 Watt
Frequency Response 20 Hz - 100 Hz
Sensitivity 87.4 dB
Components
Woofer Material Metal
Surround Material Rubber
Mounting
Enclosure Enclosed
Top Mounting Depth 6.88 In.
Bottom Mounting Depth 7.38 In.
Mounting Diameter / Length 11.19 In.
Also for sale is a audiobahn 8000t amp here are the specs:
* Class A/B MOSFET Circuitry
* PWM MOSFET Power Supply
* Semi-Double Sided Glass Epoxy Circuit Board
* THD : 0.02%
* S/N Ratio > 100dB
* Frequency Response : 10Hz - 40KHz (+ / - 1dB)
* Variable 18dB High Pass Crossover : 50Hz- 750Hz
* Variable 18dB Low Pass Crossover : 50Hz- 120Hz
* Bass boost on / off
* Subsonic Filter :20Hz - 50Hz
* RCA Throughput Connections
* 3-way Protection Circuitry : Thermal, Short Circuit, Overload, Cooling Fans
* Cobalt Blue Illumination
* High Gloss Chrome Plated Finish
* Nickel Plated Block Terminals
* Air Induction Fan Cooled
* RCA and Speaker Level Inputs
* 4 Ohms Mono : 400W x 1
* 2 Ohms Mono : 800W x 1
* Dimension(H x W x D) : 1 7/8" x 9 7/8" x 11 7/8"
Attached Thumbnails Fs: Kicker L7 12" sub w/ kicker probox-imag0014.jpg   Fs: Kicker L7 12" sub w/ kicker probox-imag0015.jpg   Fs: Kicker L7 12" sub w/ kicker probox-imag0016.jpg
Old Aug 15, 2010 | 08:05 PM
amp has been sold..
selling sub w/box for $225.00
