FS: JL Audio Cleansweep
Old Oct 3, 2010 | 10:14 AM
sexyrob's Avatar
Price: $140 Shipped to anywhere in the US
Condition: Used - Good
Pickup Price: $125
Bought this used and ended up just buying a headunit and DD kit. It's in great condition and comes with all the connectors and cables. Would be a cheap way to add a amp to your factory head unit and get great sound.
If you don't know what cleansweep does, it digitally "cleans" the incoming signal of any mess created by the factory head unit and sends a excellent signal to your amp so you get a great sound that would otherwise be further distorted.
Specifications:
32BIT DSP PROCESSOR
ROTARY **** TO CONTROL THE MASTER SYSTEM VOLUME AT THE OUTPUTS OF CL441DSP FOR THE FACTORY(OEM) SOURCE OR AUXILIARY SOURCE
4CH SPEAKER INPUT FROM FACTORY(OEM) UNIT
SIGNAL SENSE ON/OFF SWITCH
OEM(SPEAKER) LEVEL INPUT : 1 - 4CH : 100mV, 30V RMS WITH FULLY AUTOMATIC LEVEL SETTING
AUXILIARY INPUT : 1 : 250mV, 4V RMS
FRONT & REAR RCA OUTPUT
EQ RESOLUTION : 1/3 OCT. 25 ~ 20,000Hz
MASTER VOLUME CONTROL UNIT WITH SIMPLE ROTARY ****
S/N RATIO : > 102dB
THD : < 0.01% AT RATED OUTPUT (20 ~ 20,000Hz)
SIZE : 4.37"W x 1.54"H x 9.72"L
click images for hi-res
feedback:
eBay
my350z
g35driver
Old Oct 3, 2010 | 10:19 AM
freakta's Avatar
bump for good product and good price
Old Oct 19, 2010 | 09:21 AM
sexyrob's Avatar
bump
Old Nov 28, 2010 | 10:01 AM
sexyrob's Avatar
bump, someone buy this. I need brakes
Ninjay16
Audio/Video/Electronics
11
Feb 26, 2018 06:14 PM
g.spot
May 9, 2016 10:54 PM
DEMoLITIoN
Apr 20, 2016 06:57 PM
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
MrIP35
Nov 8, 2015 10:47 AM
