Need Help. 03 Coupe & I want to install 06 Headlights
I did find one post but I still haven't heard if there were any problems. Grubbs will do the work but the service tech found a few differences between the 06 and earlier models. We thought it best before starting to see if anyone else had success.
To the best of my knowldge and reading all these lighting posts....no problems. The only thing I heard of is that the passenger side wiring harness has to be extended. It's tied down to the frame and you have to cut the tie not the harness to extend it. Read in the lighting section for more info and pics
Originally Posted by slikster818
i have a 04 and i got the 06 headlights and installed it myself and i had no problems, you just plug the 06 headlights in and your done.
I know that the wiring harness is slightly different on the 06. This did not cause any issues? Thanks for your help.
Originally Posted by theeggman
What about functions on the light stick? When you turn on the fogs do they come on? Any issues with high beams?
Originally Posted by g35rcr
from where?
