help please
Old Nov 28, 2006 | 04:42 PM
g35rcr's Avatar
ill help you install it for a 6 pack...no reason in paying 100 bucks to install something that takes 20 mins
Old Nov 28, 2006 | 05:23 PM
firefox's Avatar
Does the HKS intake require the relocation of the MAF sensor from the stock pipe to the HKS pipe? If this is the case then, a special keyed torx bit is needed to get the MAF sensor off the original intake pipe. The keyed torx bit is is regular torx bit with a dimple in the center.
Just wanted to bring this up before stuff is being taken apart. A 20 minute install could turn in a couple of hours if you can't find this bit.
