Reset ECU and Car Seems Sluggish :(
Old Apr 4, 2008 | 02:22 AM
thibodeaux619's Avatar
Reset the ECU on my 04.5 5AT and car doesn't seem to respond as it previously did. Any thoughts?
Old Apr 4, 2008 | 11:01 AM
BeerViper's Avatar
After you reset the ECU, your car has to re-learn the way you drive. It's strange that it seems sluggish after resetting though??
What method did you use to reset the ECU?
Old Apr 4, 2008 | 11:12 AM
bmoon_007's Avatar
Jon with an avatar!?! lol sorry to jack you thread.
- b
Old Apr 4, 2008 | 11:38 AM
BeerViper's Avatar
^Yeah I decided it was time for a change
Old Apr 4, 2008 | 11:40 AM
waijai's Avatar
i.love.gold
oooh, what's next...new haircut?
Old Apr 4, 2008 | 11:50 AM
BeerViper's Avatar
Yeah I'm thinking about growing it out
Old Apr 4, 2008 | 11:56 AM
New to the G. I live in the Joe Pool lake area, but am back in Lubbock finishing my last year of school. I reset it using the battery disconnect method. It just seems less responsive then before.
Old Apr 4, 2008 | 12:58 PM
BeerViper's Avatar
So I assume you left the battery disconnected for 8+ hours?
How many miles on your G? Have you checked your air filter? Current on your oil change?
When you re-train the ECU, it will "learn" your driving style and adapt. If you drive very low key then the ECU will assume you don't push the motor very hard and adapt accordingly. If you drive very agressively (with the throttle) then the ECU will adapt that way...
Old Apr 4, 2008 | 01:04 PM
nghiars's Avatar
just drive fast so the ECU learns that
Old Apr 4, 2008 | 04:30 PM
g35man04's Avatar
CLUB MODERATOR
there is also a better procedure in resetting it by using the key and gas pedel method...you have to use really good timing but it works.
Old Apr 4, 2008 | 04:39 PM
BeerViper's Avatar
^+1 and this way you don't have to reset your radio stations!
Old Apr 4, 2008 | 04:46 PM
g35man04's Avatar
CLUB MODERATOR
yes sir!
Old Apr 4, 2008 | 05:22 PM
waijai's Avatar
i.love.gold
I've done the pedal method several times.
Old Apr 4, 2008 | 05:45 PM
EG3's Avatar
EG3
Ummm What Is The Pedal Method?
Old Apr 4, 2008 | 05:57 PM
BeerViper's Avatar
It's real easy ... click search, type "Pedal method ECU", find:
https://g35driver.com/forums/showthr...dal+method+ECU
