DFW - Need product tester for sway bars
Old Sep 26, 2008 | 11:58 AM
waijai's Avatar
i.love.gold
PM sent
Was there some sort of change between early 03 sedans and the other 03-07 G35 coupes or 03-06 Sedans?
Old Sep 26, 2008 | 12:00 PM
Metalp3n's Avatar
Nothing major with the suspension or sway bars.
PM me pricing info on them please, im still interested.
Old Sep 26, 2008 | 12:10 PM
waijai's Avatar
i.love.gold
Got some pictures for you all.
35mm front
22mm rear
Both together
Old Sep 26, 2008 | 12:14 PM
timsam's Avatar
PMed Back...Im in!
Just need to work out the details with you!
Old Sep 26, 2008 | 01:25 PM
BeerViper's Avatar
I'm still interested depending on price...
Old Sep 26, 2008 | 01:30 PM
BeerViper's Avatar
Are these sways adjustable?
Old Sep 26, 2008 | 03:32 PM
goofygrin's Avatar
the front looks to be (notice the hole). The rear? Not so much.
Old Sep 26, 2008 | 03:36 PM
agiraldo182's Avatar
I am interested, but I have an 08 G Sedan.
Are they making any yet?
Old Sep 26, 2008 | 05:25 PM
waijai's Avatar
i.love.gold
agiraldo182 - No plans as of yet.
Beerviper - Yes the front is two way adjustable.
Old Oct 1, 2008 | 12:14 PM
timsam's Avatar
Installed (i couldnt wait)
Lookie what I got in!!!
Order was put in on Monday and I got it delivered to my door on Tuesday via UPS!
Initial Reaction: They were wrapped and shipped very secure and protected. Package contained the front and rear bars and a piece of paper that I'm assuming are instructions (but it was written entirely in Japanese). The sway bars looked great and felt solid.
Installation: Pretty simple and straight forward (roughly 30min – 1hour). I used my service manual as reference.
-Rear…remove two beauty covers. Then remove the connection to the “Stabilizer Connecting Rod” (location-red arrow), the remove the nuts on the “Stabilizer Bushing and Stabilizer Clamp”(location-green circle). Do this on both the left and right side. Then you can just slide the Rear Sway Bar (Stabilizer Bar) out.
Remove the “Stabilizer Bushing and Stabilizer Clamp” from the OEM bar and install it on the New Bar. (NOTE: the bushing will not close completely since the new bar is roughly 1 mm thicker).
Then just reinstall the New Bar and be sure to correctly torque the “Stabilizer Clamp” and the connection to the “Stabilizer Connect Rod”. Also reinstall the beauty covers and you are done with the rear.
-Front…remove the front tray and the two side pieces of plastic that are near the “Stabilizer Clamp” Then remove the connection to the “Stabilizer Connecting Rod” (location-red arrow). However you will need to remove the Stabilizer Connection Rod completely (top and bottom) to slide it off of the Sway Bar. Then remove the nut and 3 bolts on the “Stabilizer Bushing and Stabilizer Clamp”(location-green circle). Do this on both the left and right side. (BEWARE THAT IT WILL DROP ON YOU IF YOU ARENT HOLDING IT UP) so carefully drop the Front Sway Bar (Stabilizer Bar) out.
Just like the rear, Remove the “Stabilizer Bushing and Stabilizer Clamp” from the OEM bar and install it on the New Bar.
Then just reinstall the New Bar. There are two different holes for stiffness settings. I assumed the ones closer into the bar are stiffer…so I chose that one. I found this picture on the "instruction" sheet included:
So my assumption is that the first hole is 20% stiffer and the second hole is 37% stiffer.
The ”Stabilizer Clamp’s” installation has its own pattern.:
“Tighten each bolt and nut as shown in the figure for tightening the stabilizer clamp. Tightening order is as follows.
2 (temporarily tighten) → 3 (temporarily tighten) → 2 (fully tighten) → 3 (fully tighten) → 4, 5 (temporarily tighten) → 4, 5 (fully tighten).” (ignore bolt 1, you don’t need to mess with it).
Be sure to correctly torque the “Stabilizer Clamp” and the connection to the “Stabilizer Connecting Rod” (top and bottom).
Also reinstall all three beauty covers and you are done with the front.
____________________________
So overall, pretty simple. This was done pretty late at night so I haven’t had the chance to test drive. That will be coming up!
General Comments: Wish there were instructions in English, and that it had more specs on the differences between OEM. Cause honestly the only difference I could tell was that the rear is approximately 1 mm thicker, and that they weighed just a little bit more than OEM. So I have no idea on the exact specs and the difference of stiffness with the two stiffness positions in the front. Oh and they are a nice color of Blue!!!
Also, I was hoping there would be new “Stabilizer Bushings”, especially since the rear is thicker.
Test Drive coming soon….I'll be testing this setup on the 2.9 mile road course at Texas World Speedway this weekend!
Old Oct 1, 2008 | 02:29 PM
waijai's Avatar
i.love.gold
Awesome, thanks for the writeup man. Can you post this up in the suspension forums of g35driver, my350z, etc?
Old Oct 2, 2008 | 03:30 PM
timsam's Avatar
Sure thing. I will post them there once I add the testing information!
Old Oct 14, 2008 | 10:09 AM
timsam's Avatar
Ride Review
Sorry for the delay guys, just got a little overloaded at work.
So…
I think the car drives a lot better. When I took my first turn I definitely could tell a difference. With the sway bars, the turning is more tight and feels good. The ride quality is still the same, it hasn’t gotten any stiffer, from what I can tell.
Out on the track I could tell there is less body ‘sway’ (or body roll) than before. So that is always good.
Overall, these sways bars have been a very good purchase. Simple Install, and noticeable difference in turning and body roll.
Two Thumbs Up!!!
Old Oct 14, 2008 | 11:11 AM
waijai's Avatar
i.love.gold
Thanks for the feedback Tim. Can you post a consolidated thread with your initial impressions, install, and post install impressions in the suspension forums here and my350z?
Old Oct 14, 2008 | 03:40 PM
  #30
timsam's Avatar
Done!
g35driver
my350z
