[DFW] What have you done to your G Today?
Hmm, that one was low on air the first time i had the car but i never checked it again. Just thought it was a bit low. May have had a small leak or crack and got worse
Good luck w/ that.. You're gonna be in the same boat as I was.. Venaci are made by WORK..
So Sick and these are going to Look good on my ride as well. 20x13 or 14 8 inch lip. Consult with them this week.
ordered Philips ultinon 6000k D2S Bulbs today! finally will have a legit pair of bulbs..unfortunately my ones from MM I have had issues with..the 6000k driver side one would never stop flickering when I hit a bump...passenger side never did it once...so I took them out and switched to my 8000k ones. Sure enough same issue. checked the ignitor and the ignitor doesnt fully tighten around the bulb because the to looking points on the bulb itself are smaller than the OEM therefore allowing play isnide the ignitor.
I think re-installed back my OEM 4300k and havent had an issue with flickering yet.
I ordered legit Bulbs "philips replacement 6000k" to see if when installed if they flicker or not. If this dont solve my problem I will have to take a look at the driver side headlight and make sure everything is tightened down all the way from vibration and movement.
