Torn Ball joint
Old Aug 31, 2011 | 12:40 PM
mealad's Avatar
Torn Ball joint
My front driver side ball joint that connects the lower control arm to the knuckle is torn and makes a mattress spring type noise when I turn the wheel. I think I should repair this, but I am not sure what part to order. Should I buy the whole knuckle from infiniti or is there another place where I can just buy just the ball joint? Also, should I replace both sides or just the side which is torn?
Thanks in advance for y'all help.
Old Aug 31, 2011 | 12:57 PM
ezpotato's Avatar
i dont wanna be the immature azz who doesnt contribute, but i think Jackus on this forum has torn his ***** at the joint too....
I would wait till someone chimes in, but it should be an easy replacement, might as well do both, esp if you're aggressive on your car and have high miles.
Old Aug 31, 2011 | 12:58 PM
g35man04's Avatar
CLUB MODERATOR
if ones is busted there most likely your passenger side will go soon.
http://cgi.ebay.com/ebaymotors/2-FRO...item4aad60b908
JaE35's Avatar
Moderator
G35 Sedan
Whs ^
Old Aug 31, 2011 | 02:43 PM
mealad's Avatar
Will these ebay ones fit correctly for an 03 sedan or is some adjustment probably needed?
Old Aug 31, 2011 | 02:44 PM
g35man04's Avatar
CLUB MODERATOR
both the same across the board.
Old Aug 31, 2011 | 03:43 PM
acidjake75's Avatar
those are fun to press out...hehehehe..
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
The Fixer
Steering & Suspension
Nov 1, 2015 03:26 PM
AL8782
Oct 3, 2015 10:26 AM
Jeff T
Sep 30, 2015 02:00 PM
