Drag NHRA, IDRC, IHRA, NDRA
How to get rid of axle hop
Old Sep 7, 2009 | 04:29 PM
cjet427's Avatar
I went to the 1/8 mile track with my friends ('09 Altima 3.5S & '09 MS3) and we were doing some passes. I tried various launch RPMs, from 2500-3500, but always got axle hop. My best time of the night was 9.7 @ 74 mph (only had the car for a week).
Anyway, what's the best way to get rid of all the axle hop that I get through all of 1st gear? Slowly let off the clutch, or just let off the gas a little?
I have Kumho Ecsta Z-Rated 285 tires (I know, they're huge), Exedy Stage 1 Clutch and Solid Lightweight Flywheel. on an 04 Coupe 6MT
Please Help!!!
Old Sep 7, 2009 | 10:51 PM
rpm06g35's Avatar
go on this link and ensure to check out the last set of install pics.
https://g35driver.com/forums/sfl-g-c...light=wheelhop
Old Sep 8, 2009 | 11:20 PM
RADIOGUY21's Avatar
what tire pressure were you running? I experienced some wheel hop at the track but after dropping the pressure down to about 24-25 PSI it stopped and not to mention helped with traction.
Old Sep 9, 2009 | 04:31 PM
cjet427's Avatar
I never lowered tire pressure (kinda last minute, "let's go to the track" thing).
Also, I bought test pipes, but haven't put them on yet. called some muffler shops about having them put them on, but they won't for legal reasons. Any ideas? What will I need to put them on myself? (they have the CEL fixes)
Old Sep 10, 2009 | 12:03 PM
DaveB's Avatar
You've kind of screwed yourself for racing at the strip.
1) The big rims and large tires have a lot more weight therefore they're harder to control once spinning.
2) The wide tires have narrow contact patches for launching. They're better for lateral Gs, but horrible for off the line traction.
3) The lightweight flywheel has reduce stored energy which will make the car much harder to launch. Either it's bog city or excessive wheelspin.
The fix?
1) Put your OEM wheels on when racing at the strip.
2) Rev up to around 3000rpms. When it's time to go, release the clutch enough so that you feel the car start to roll. Once you feel the roll, quickly release the clutch while feeding it gas. The goal is to keep the rpms above 3500rpm or so. You might not be able to go full throttle until 5000-5500rpms. The key to launching a manual is not to get excessively greedy with the throttle and shock the tires/drivetrain.
Old Sep 10, 2009 | 12:22 PM
Klubbheads's Avatar
^what he said.
Old Sep 10, 2009 | 04:14 PM
rpm06g35's Avatar
Basically you have 3 bolts holding the rear pumpin up to the body. The 2 up front basically prevent (damper) side to side roll of the rearend. The rear bushing in the carrier frame that bolts to the stud (that is on the cover) prevents front to back pivot. The front to back is basically allowing the pumpkin to hop and slap against the body of the car. Lock that up and your wheel hop isnt bad at all. I run 275 drag radials and have the lightened flywheel/clutch combo as well. I dump my clutch pretty high and hammer down till I make it past the 1320 mark. Feathering the clutch will just cause premature wear on it. Pm me if you have any questions
Old Sep 10, 2009 | 05:42 PM
DaveB's Avatar
Originally Posted by rpm06g35
I run 275 drag radials and have the lightened flywhell/clutch combo as well. I dump my clucth pretty high and hammer down till I make it past the 1320 mark. Feathering the clutch will just casue premature wear on it. Pm me if you have any questions
You've got DRs. He's got street tires. That's a big difference in terms of what the tires can handle on a launch. Clutch slipping or lowering the launch rpm is his only hope.
Old Sep 10, 2009 | 05:57 PM
rpm06g35's Avatar
Dave when I run my street tires at the track 285 30 19 mich's they dont hop. They dont grab but eventually they get traction, no hop.
Old Sep 11, 2009 | 12:34 AM
undefeated350gt's Avatar
yup no hop!!!! ive seen this in person
Old Sep 20, 2009 | 02:26 AM
rpm06g35's Avatar
check the link again i completed the install (added the top bushings)
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
Danielek
Sep 18, 2015 12:16 PM
AuAltima3.5
Drivetrain
Sep 13, 2015 10:36 AM
