Drag NHRA, IDRC, IHRA, NDRA
first time at track
Old Apr 23, 2012 | 09:20 AM
eodg35's Avatar
first time at track
04 coupe, auto. let the car do the shifting, which i now realize is a bad idea. Held down brake and released between 2-3k spun out each time(track prep was not the greatest) had very slow reaction.
.52 reaction, 2.6 60 ft, 15.4 et, 92 mph
.95 reaction, 2.3 60 ft, 15.06 et 90.96 mph,
im pretty sure that if the track prep was better, if i had done the manumatic shifting and if i could react better id be running low 14's like i should be.
kinetix v+ plenum
injen short ram intake
tein basis
rear camber kit and toe bolts
Old Apr 23, 2012 | 09:55 AM
freakta's Avatar
from my experience in these cars, which isnt much, i keep it in ds mode and only shift it at the end of the track to keep it in third.
i tried building pressure in the transmission but didnt do it enough. so your on the right track... but if your having trouble with wheelspin id say roll on the throttle, dont expect your tires to do all the work
Old Apr 23, 2012 | 10:03 AM
eodg35's Avatar
so in second gear put it in manumatic to keep it in third, and i think that if i go on a night that they prep the track better, and it doesnt rain right before i shouldnt spin to much
Old Apr 23, 2012 | 11:06 AM
herrschaft's Avatar
Just use tiptronic the entire time. Did you lower the PSI in your rear tires at all? Your 60' should be around 2.1-2.2
Old Apr 23, 2012 | 11:15 AM
eodg35's Avatar
No i didnt lower psi, and does reaction take away from 60 ft?
Old Apr 23, 2012 | 11:24 AM
herrschaft's Avatar
No. The clock for the 60' doesn't start until the car moves. I never cared about reaction time since I usually race for time, not to beat the car next to me. Next time let air out of the rears and see how that works for the launches, I usually go down to 20psi.
Old Apr 23, 2012 | 12:04 PM
freakta's Avatar
Depends on the tires as well if lower pressure works better. It also doesn't hurt to try. Get consistant times and then mess with the tire pressure.
And yes better day better weather and prep will help but you should be faster any ways, also what is you elevation
Old Apr 23, 2012 | 12:22 PM
eodg35's Avatar
Not sure in missouri
Old Jun 14, 2012 | 02:41 PM
IP05G35's Avatar
If the track is not hooking when you stall it up you need to launch off idle and flash the converter. You will run much better.
Team STILLEN
Aug 10, 2015 08:17 PM
joel extreme
SOCAL Meetings & Events
Aug 7, 2015 03:09 AM
joel extreme
Jul 27, 2015 11:59 PM
joel extreme
Jul 23, 2015 04:13 AM
