lighter flywheel questions?
Old Nov 5, 2006 | 10:41 PM
ac419's Avatar
hi i'm looking into getting a lighter flywheel and i was wondering if i have to upgrade to a aftermarket clutch or if i can keep the stock clutch? would a lighter flywheel also make your revs faster? just looking to some ways to make the G quicker before FI. thanks.
Old Nov 5, 2006 | 10:58 PM
GLuXuRy's Avatar
you can keep the stock clutch assembly...but why would you wana do that if your gonna do the flywheel...while everything is accessible...might as well through in a new clutch assembly...and yes i do believe a lightened flywheel will bring revs up faster...dont know how much of a difference though
Old Nov 5, 2006 | 11:08 PM
ac419's Avatar
i think what i'm trying to do is go faster in a straight line for now.. until i get suspension.. what kind of flywheel do you have? and how much roughly was the install?
Old Nov 5, 2006 | 11:10 PM
GLuXuRy's Avatar
my car is stock...i dont have a MT tranny either...so im only speaking from knowledge...not personal experience...i know Jim Wolf Technology has a flywheel and they are a well respected company
Old Nov 5, 2006 | 11:21 PM
ttrank's Avatar
Grocery getter
Most aftermarket flywheels will work with the stock clutch but I would change it while you are in there. I know that UR, JWT and most of the other oem size ones will work.
It does bring the revs up faster. The oem is ~28lbs and my UR is 12lbs.
Make sure you can deal with a little chatter if you get one. The UR is one of the best but does still have a little chatter.
Old Nov 6, 2006 | 02:02 AM
bobshuai's Avatar
anyone knows what cost the chatter of light fly wheel?
Old Nov 6, 2006 | 02:06 AM
ISMSOLUTIONS's Avatar
Lightened flywheels work well - you'll get higher mile per hours in a 1/4, but slower 60ft times. The increase is felt/seen mostly in the mid-range. You will also get far more noise and vibration out of the MT gear train. The reason they are heavier is for dampening on the flywheel.
Rick
Old Nov 6, 2006 | 03:00 AM
GReddySetGO's Avatar
You can use a lightweight flywheel with the stock clutch. But the labor to put that flywheel in there, I would just do the clutch at the same time, instead of doing it again later.
Here are a few available with their weights:
ACT Prolite flywheel (13.2lbs)
ACT Streetlite flywheel (16.9lbs)
Fidanza aluminum flywheel (13.5lbs)
Jim Wolf flywheel (14lbs)
Exedy and Spec both make flywheels too, but I am unsure of their weights.
Old Nov 6, 2006 | 09:34 AM
g35rcr's Avatar
keep in mind some flywheels will only work with their clutches such as rps...i had to swap out my rps clutch for a stock 300z twin turbo to get the stock setup back but keep the flywheel...luckily the clamping force is only 100kg diff
Old Nov 7, 2006 | 12:20 AM
ttrank's Avatar
Grocery getter
If you are asking what causes the chatter is is because the oem flywheel is a dual mass two piece and the lightened ones are one piece aluminum. The transmission noise is transferred through it.
Old Nov 7, 2006 | 12:23 AM
Hence my post regarding dampening....
Rick
yosip1115
Aug 26, 2015 10:46 AM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
beevanhuynh
Jul 14, 2015 09:06 AM
