need help to choose a aftermarket clutch kit
Old Mar 30, 2007 | 12:02 AM
Reddragon's Avatar
Exclamation need help to choose a aftermarket clutch kit
Hey guys I need your help, which clutch kit should buy for my G?
My oem clutch is already gone, so I was thinkin' about buyin' a aftermarket one, a better one.
Old Mar 30, 2007 | 12:59 AM
trey.hutcheson's Avatar
An aftermarket clutch is a very critical decision, and requires quite a bit of research. The JWT kit is very popular. I myself chose the clutchmasters stage1 kit. There are plenty of others available as well.
Part of the choice when dealing with an aftermarket clutch is whether to go with a lightweight flywheel, or to stay with the OE unit. Like the clutch, there are plenty of aftermarket alternatives that offer different weights and produce differing amounts of the typical cement mixer noise.
Before you pull the trigger on anything, spend a few days researching the topic. There are plenty of threads regarding aftermarket clutch and flywheel combinations that have been posted over the years. Some of us have written reviews and even provided video to demonstrate the sound. And then there's always my350z.com, which has an even larger pool of threads available for research.
Research Research Research.
And one more thing - if you go aftermarket, go ahead and get a stainless steel clutch line and have it put in at the same time. They go for around $50, and will save you some clutch pedal fade in the future.
11bEMT
May 27, 2022 03:13 PM
RA081024
Aug 18, 2015 07:03 AM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
andrewvk
Interior
Aug 6, 2015 05:51 PM
Jussaku
Aug 4, 2015 12:45 PM
