Too much fluid in tranny
Old Apr 28, 2007 | 03:18 PM
TheTick's Avatar
The dealer told me that they use about 3-3.5 quarts on a drain and fill. I drained and replaced 3 quarts and checked the dipstick after driving it a bit. The fluid is about 1 inch above the max fill line. Should I drain some out?
Thanks for your help!
Old Apr 28, 2007 | 05:32 PM
jjyellow's Avatar
Are you running the car when you check it. Leave car in park and turn on motor let it warm up and check while idling in park. You are gonna need more than 3quarts
Old Apr 28, 2007 | 07:16 PM
TheTick's Avatar
Thanks for your response jj. Yes, I did what you described. I also checked it cold this morning and it was still way over the fill line.
Old Apr 28, 2007 | 08:59 PM
Boston's Avatar
If it's over serviced, the excess fluid will exit under pressure via a blow out valve under hard driving conditions which will end up on the under side and back end of your car. If the dealer serviced the tranny, it should have been a flush and fill using a fluid exchange machine so I'm surprised the over serviced. Take it back to the dealer if it truly is.
Old Apr 29, 2007 | 11:12 AM
TheTick's Avatar
Thanks Easein, I did it myself so I'm glad to hear that I'll be ok.
f22raptor
Mar 18, 2016 08:50 AM
AL8782
Oct 3, 2015 10:26 AM
