General clutch warranty question?
Old Jul 12, 2007 | 10:55 PM
ideezie's Avatar
Originally Posted by StarChamp
The StreetLight is definitely better for daily driving than the ProLight, and that's an average price. But $650 for a clutch is outrageous, unless you're buying a full-on ceramic racing clutch, and then it's a steal. I don't know what other mods you've done to your G, but you can get a clutch that will handle up to 375 ft/lbs of torque (F1 Racing Stage 2, XTD Stage 2, etc.) for $250 +S&H. There's also a JWT flywheel/clutch combo on ebay for about $750 +S&H. Unless you wedded to ACT (and even then), you should be able to find a clutch for under $400. Personally, I'd never pay more for a clutch than the flywheel, but then I'm running NA and I don't drag my car.
Also, make sure that whatever you get, the clutch kit should come with an alignment tool, especially if you re-think doing it yourself (the high-end ACT kit I looked at didn't come with one). If you have Nissan/Infiniti replace your clutch, they'll probably have one, but your local independent mechanic might not, and that could make installation extremely difficult and end up taking a lot of time if one has to be ordered.
Damn I thought I was getting a deal. Not sure if the clutch is a full-on ceramic racing clutch, all I know is the clutch was orignially 860 and I talked him down. I'm really green when it comes to all this racing stuff. I didn't order online because my car is totally down and I didn't want to wait. The warehouse is in my city and I was able to get the parts right away. The way i'm looking at it is, it's cheaper than the dealer quote and Im getting better quality and performance. The whole job is costing me $1600 and the dealer quote was 2200. You're scaring me about the alignment tool though.
Old Jul 13, 2007 | 12:01 AM
StarChamp's Avatar
The alignment tool is probably a $2 item, just a plastic rod shaped like the transmission input shaft. It's not impossible to install a clutch without it, just frustrating and time consuming.
Old Jul 13, 2007 | 02:33 AM
04NismoV35's Avatar
Originally Posted by ideezie
Just how loud will the noise be? and is there an aftermarket flywheel that is less noisey?
That's a subjective question. On my setup the noise starts at around 900-1000rpm, then tapers off quickly around 1500 rpm and is pretty much gone by 1800 rpm. The severity of the noise is dependent on how hard you accelerate, harder = louder, feather light/granny = softer. Since I tend to drive somewhat aggresively I always hear it and I rarely do 2nd gear starts anymore which I miss a bit when driving slowly through my neighborhood. I'm not sure how much more/less noisy others are since this was the first time I had done these type of mods. I did it because I lost faith in the stock components as well as the super high cost of the inferior factory units.
The only reason I chose the Clutchmaster and more so the Fidanza was that they were reccomended by a shop (TKX Performance in Huntington, NY) that I trust, that races Porsches and works on the them as well as Bimmers, Benzes, Lambo's and Ferrari's. Both were good values and high in quality but if I had a bit more insight I might have chosen a heavier/quieter flywheel to maintain a bit more of a smoother feel.
Another thing that I noticed is that the combo produced slightly different results on two different trannies put in at the dealer. Luckily the second one (the one I'm driving one now) is slightly better and seems to have quieted down a little since, or maybe I'm just getting used to it. Another thing suggested to me by that shop is using a 50/50 blend of REDLINE gear oils including a product called Heavy Shockproof that has weight equivilant to 75W250 and has a glue/molasses like consistency to help dampen the gear meshing noise.
As far as availability, once you've made you choice do a dealer/distributor search and make a few calls. I actually found the Fidanza in stock locally and paid $465 b4 tax and shipping. The Clutchmasters ($323) had just been sold out, but was a normal stock item for the distributor. Another local distributor had ACT stuff in stock, but JWT was nowhere to be found here in NY.
Sorry for the extra long blah, blah, hope this helps.
Mo, the JWT is the lightest flywheel that I know of for the VQ35, but 'best' means many things to many people.
BTW, the JWT is listed as 14lbs and the Fidanza is 13.5lbs, not that you'd really feel the difference tho , however JWT probably knows Nissan's and the VQ's a lot more.
If you do a lot of road racing or even just heel-toeing on the streets, a lighter flywheel will allow you to match revs easier when downshifting. You do have to pay a bit more attention to what you're doing though, as it's very easy to push it past redline very quickly.
OMG how true that is, I can finally rev match smoothly after having the car 3 years, a much bigger pleasure when going for 'spirited' drives. The engine is much more eager now as well, that redline comes up fast and can catch you off guard.
Old Jul 13, 2007 | 03:42 AM
kenasaki's Avatar
how do you know if your tranny needs replacing?
Old Jul 13, 2007 | 03:48 AM
04NismoV35's Avatar
It usually manifests as a shifting problem. Mine 1st one gave me a grind/scrape into 5th. The second one whined like a pig and gave me trouble going into 1st. The 3rd only has about 1k on it and seems much better that the others. Other's have had issues 3rd and reverse. I complain a few time to the dealer about the 1st one and persisted for about 10-15k miles until they finally agreed there was a problem.
Are you having issues?
Old Jul 17, 2007 | 06:11 PM
Mo's Tre' 5's Avatar
thanks star...one other question..do u actually have to get a flywheel if u change out ur clutch?
Th611
Oct 27, 2015 03:48 PM
Team STILLEN
Aug 10, 2015 08:17 PM
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
vstypicals
Jul 20, 2015 10:55 PM
