Lowered Clutch and now won't shift
Old Aug 22, 2007 | 10:12 AM
HITMANVQ35's Avatar
I lowered the clutch by turning the bolt on the clutch assembly. Everything was fine for couple of days, enjoying the new feel and all. But then one morning it was noticeably harder to shift into gear. Once I got going it became smoother shifting. So I adjusted the bolt to about 2.5 turns rather than 3 turns before.
And everything was fine for about a month. The other day it was harder to shift than the first time I encountered the problem. I'm going to try to set the pedal back to stock position today.
Anyone know why I have this problem?
Old Aug 22, 2007 | 10:20 AM
jclit's Avatar
Well you most likely screwed up somewhere. Ive had it for about 6 months with no problems.
Old Aug 22, 2007 | 10:23 AM
kvangil's Avatar
Maybe you're not tightening the nut enough so it's adjusting as you're driving? I've had mine adjusted for about 6 months now also, and no issues. I only went about 2 turns, but that was good enough.
Old Aug 24, 2007 | 11:00 AM
RedondoG's Avatar
Put it back to stock and put in the D-Wolf clutch kit.
jsimonk
Dec 22, 2023 03:49 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
mdzukunft
Drivetrain
Aug 25, 2015 10:28 AM
NemesisGee
Aug 11, 2015 07:10 PM
Buggzb86
Drivetrain
Jul 25, 2015 11:22 PM
