need help w/ clutch b4 going to dealership PLZ!
Old Mar 23, 2008 | 08:07 PM
kenasaki's Avatar
i've had my 05 6mt sedan for 1 1/2 years now. As many know, those years have a high engagement point. All day today, the clutch seems to be "stuck" down to the floor. The engagement point now; it doesn't come up high like it use to, AND now, I can barely get into 1st, 2nd, 3rd, 4th, and REVERSE! WTF?! Its like i have to force it in hoping it'll go in. i know i didn't do anything wrong. It Grinds like a B*tch now!
Is it my syncros? or is it just the assmebly? or the short shifter i installed? or does the whole transmission need to be replaced. Someone said that if the brake fluid is low, the clutch will stick to the floor like that, but thats STUPID. brake fluid and clutch has no affiliation.
HELP! PLEASE! NEED HELP! I hope they dont give me bs about the lowering of the car.
Old Mar 23, 2008 | 08:34 PM
Mr.GEE's Avatar
20 Year Member
Check the CLUTCH FLUID level. The reservoir is located next to the brake master cylinder reservoir. Whoever told you to check the brake fluid was partially right. The clutch hydraulic systems uses DOT 3 brake fluid. If it's low, check under the car for leaks.
Old Mar 23, 2008 | 08:36 PM
kenasaki's Avatar
what kind of clutch fluid does it use? i'm going to check it right now.
Old Mar 23, 2008 | 08:37 PM
Mr.GEE's Avatar
20 Year Member
DOT 3 brake fluid
Old Mar 23, 2008 | 09:01 PM
kenasaki's Avatar
just checked it, and all the fluids are at max. Also, for some reason, the clutch isn't stuck to the floor anymore. its back to its high engagement point but still a little rough.
u guys think it was because it was really hot and i was stuck in stop and go traffic for 35 mins and the AC on the whole time?
Old Mar 24, 2008 | 01:24 AM
1SlowSedan's Avatar
05 6mt sedan owner here too with the same exact problem. also my clutch starts acting up when i blast the ac. do any of you guys know whats up?
Old Mar 24, 2008 | 08:10 AM
Hotnikks's Avatar
Guys try changing your clutch fluid!! If it's brown and dirty it time to change. should be nice and clear. there is a diy somewhere on this site for that I think search for it.
Old Mar 24, 2008 | 08:15 AM
Hotnikks's Avatar
Guys go read this thread
https://g35driver.com/forums/showthr...g+clutch+fluid
Old Apr 8, 2008 | 02:32 AM
1SlowSedan's Avatar
hey guys i've been having the same issue. but also my clutch is starting to get harder to engage. feels like i have a 10 lb. clutch. if i follow ranger's maintenance would my clutch become softer?
Old Apr 8, 2008 | 11:02 AM
Hotnikks's Avatar
^^your clutch might be going out. Check for slippage over the next few months
Old Apr 9, 2008 | 12:13 AM
06CoupeDaddy's Avatar
Could be flushing the fluid would help, but I suspect it's the clutch master cylinder. It'll get really bad if it's hot, or you're getting on it a bit. Well known problem at Infiniti. I'd just take it in and have them replace it. (And get a new nice G37 sedan loaner!)
11bEMT
May 27, 2022 03:13 PM
mistermojorizin
Drivetrain
Nov 2, 2006 06:23 AM
2Evolved
Jan 12, 2006 12:38 PM
AuxNuke
Sep 29, 2003 09:55 PM
